Discuss
Electronic clock control
 in
I am looking for a some kind of answer as to why the control part that turns on the oven (
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Electronic clock control
  #1 (permalink)
Old 10-15-2007, 02:29 PM
peter e peter e is offline
Junior Member
peter e is on a distinguished road
Default Electronic clock control
Model Number: fefb67bhde   Brand: Frigidaire   Age: 1 - 5 years
I am looking for a some kind of answer as to why the control part that turns on the oven ( also call the clock ) keeps burning up. So far I have replaced the part three times at 140 a pop. Does any body have a answer??
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-26-2007, 05:31 PM
Junior Member
Smile Electronic Clock Repair
I guess I can answer my own clock problem. After recieving a new clock Part # 31818545 and taken meter readings on the old and new I removed a resistor on the z3 location . I found out or at least thought it was bad since my Fluke meter told me so . After I had the resistor in my hand I used my Simpson meter and set it on 10,000 ohms it showed me it was good. So I put it back on the board and my clock control came to life. The only possible concluson is that since the resistor heats up there was a cold solder joint on it . That tells me that this is not a one time thing since this is my third clock counting the the unit that came with the stove. I also told me not to trust the electronic Fluke meter and to stick to the old needle meter.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electronic clock not working zirk12 Oven Repair (including Ranges and Cooktops) 1 03-27-2008 11:32 AM
Electronic Control Part 2307028 belmore Refrigerator & Freezer Repair 4 01-14-2008 08:14 PM
Dishwasher N/F; Electronic Control Replaced Strong Dishwasher Repair 0 09-20-2007 08:29 PM
mixer - electronic conversion 110 -220 chrisssy General Talk 1 08-30-2007 02:34 PM
Electronic Oven Control andye Oven Repair (including Ranges and Cooktops) 3 08-01-2007 08:45 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
