My 1995 Whirlpool Oven Does Notcome Up To The Proper Temperature. It Takes Over 10 Minutes To Get To 250 Degrees When It Is Set For 350 Degrees. It Takes Another 10 - 20 Minutes To Get Up To 325 Degrees. It Will Never Get To 350 Degrees. Sometimes It Never Goes Past 275 Degrees. You Just Never Know What Temperature You Will Get Or How Long It Will Take To Get There. I Have Replaced An Oven Sensor With No Improvement. COULD IT BE THAT THE ELEMENT IS DEFECTIVE?
