| » gas stove door stuck shut with error codes |
Model Number: MGR5750ADW Brand: Maytag Age: More than 10 years
Hello, Feb 4 /11
My Stove door will not open, I pressed the self clean button yesterday to clean my stove, and 2hrs later the stove began beeping and flashing 2 codes at me F1 and F3. I waited 10hrs to see if it would go threw the cycle and finish but the door will not open. I've unplugged the stove for several minutes and plugged back in. Nothing, the Stove has the same codes appear F1 And F3 and the stove door will not open. I have it unplugged as it still beeps periodically with the codes. Please can you recommend somthing else I can try. Thanks Rochelle Ads By Google Related Models |
Rochelle,
The instructions on how to open the oven door are attached to the reply. Remove the rear cover for the control panel. Locate the 5 pin connector on the control board. Unplug it and check the resistance between the two wires connected to the pins #4 & #5. The normal reading should be about 1100 Ohms at the room temperature. If the reading is wrong, replace the oven sensor (#5 on the diagram). If the reading is correct, replace the control board. - The oven sensor Part number: AP4009456 - The control board Part number: AP4008559 Here are the breakdown diagrams and Replacement parts for MAYTAG MGR5750ADW RANGE- S/C F/S GAS | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
Thanks so much for the information I will give this a try.Also if I need to order parts can I order from this website? I'm in Canada Calgary Alberta Thanks Rochelle |
You are welcome Rochelle.
As far as I know APP does not ship parts outside of US. The only way is if you know anybody in US who can place the order for you and then ship it to you. Gene.
__________________
Gene,
Thanks soooooo much we figure out the problem from your help and it ended up being the the oven temp. sensor like you had said. This is such a great site!! Thanks very much for all your help saved us some much needed dough (lol) I'd gladly recommend this site to anyone Thanks again, Rochelle |
You are welcome Rochelle. I'm glad you were able to fix it.
Thank you for the feedback. Gene.
__________________
| Display Modes | |
| Whirlpool Codes? Do not seem to be error codes | taranewblue | Oven Repair (including Ranges and Cooktops) | 4 | 06-21-2010 06:21 PM |
| frigidaire error code F10 - not listed in your error codes | Skully26 | Oven Repair (including Ranges and Cooktops) | 2 | 02-16-2010 04:29 AM |
| Maytag door is stuck shut | KatSch | Dishwasher Repair | 0 | 01-08-2010 08:51 AM |
| Error Codes | ekudd | Dishwasher Repair | 1 | 10-18-2009 09:19 AM |
| FL Error Code, Door Latch Stuck Closed | buccolts | Washer Repair | 1 | 10-01-2009 02:53 PM |
