| » Oven Does Not Heat Up |
Model Number: FEF375ESA Brand: Frigidaire Age: 1 - 5 years
I have voltage to the baking element and broil element but no current. I have check the elements with a ohm meter it shows good . I check the temp prob it showed 1100 ohm. Could the clock/timer broad be bad?
Replacement parts for FRIGIDAIRE FEF375ESA Frigidaire/electric Range | AppliancePartsPros.com Here is the tech sheet Replacement parts for FRIGIDAIRE FEF375ESA Frigidaire/electric Range | AppliancePartsPros.com I am assuming that the stove top runs OK. If the wiring from the control board to the elements is OK then odds are the control board is shot. The unit does not show a thermal cut-off.
__________________
| Display Modes | |
| Gas Oven Broiler Works but oven to bake will not heat | Lisa Cline | Oven Repair (including Ranges and Cooktops) | 1 | 11-11-2010 12:07 PM |
| Main oven does not heat but the stove top and the bottom oven work | wes2ii | Oven Repair (including Ranges and Cooktops) | 5 | 09-23-2010 01:22 PM |
| Whirlpool gas oven broiler works, but oven does not bake or heat up | smolesen | Oven Repair (including Ranges and Cooktops) | 0 | 03-13-2010 10:02 AM |
| Wall oven will not heat/re-heat properly | dottavio | Oven Repair (including Ranges and Cooktops) | 0 | 01-07-2010 09:47 AM |
| Oven/clock Control Panel is no longer lit but oven does heat. | jthomas@abrakadoodle.com | Oven Repair (including Ranges and Cooktops) | 1 | 12-05-2009 04:07 PM |
