Discuss
KitchenAid Oven is Dead
 in
Turned off the circuit breaker for the oven and when turned back on, the display/touchpad panel was dead (no lights
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » KitchenAid Oven is Dead
  #1 (permalink)
Old 12-09-2008, 09:03 AM
Junior Member
texanokie is on a distinguished road
Default KitchenAid Oven is Dead
Model Number: KEBS277DBL4   Brand: Kitchen Aid   Age: 5 - 10 years
Turned off the circuit breaker for the oven and when turned back on, the display/touchpad panel was dead (no lights on). Was working prior to cycling power. Checked power at oven terminals and found OK (240/120). Checked the control transformer primary and found to be dead. Found what appears to be a fuse on the rear of the control board (left of center at top) that is open. Reads open with ohm meter and reads 0 volts on left side with power on. Thermal fuse to control board checks Ok with ohm meter. My questions are:
1. Is this really a fuse (I couldn't see it too good and didn't have a magnifying glass) and can it be replaced.
2. Is there possibily something else bad in the control board that blew the fuse or some other component in the oven.
3. Would cycling the power to the oven have blown the fuse.
4. Should I replace the control board
5. Should I call the repairman
Thanks for any help.
Related Models
Whirlpool KEBS277DBL4 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS277DBL6 27" BUILT-IN ELECTRIC WALL OVEN
Whirlpool KEBS277DBL7 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS277DBL8 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS277DBL9 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS277DBT10 BUILT IN OVEN, ELECTRIC
Whirlpool KEBS277DBT11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS277DBT12 OVEN
Whirlpool KEBS277DBT6 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS277DBT7 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS277DBT8 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS277DBT9 BUILT-IN ELECTRIC OVEN
KitchenAid KEBS277DHW2 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS277DWH1 Built-In Oven, Electric
Whirlpool KEBS277DWH10 BUILT IN OVEN, ELECTRIC
Whirlpool KEBS277DWH11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS277DWH12 OVEN
Whirlpool KEBS277DWH2 Built-In Oven, Electric
Whirlpool KEBS277DWH4 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS277DWH6 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS277DWH7 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS277DWH8 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS277DWH9 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS277SBL0 ELECTRIC BUILT IN OVEN
Whirlpool KEBS277SBL00 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS277SBL02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS277SBL04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS277SBL1 ELECTRIC BUILT IN OVEN
Whirlpool KEBS277SSS00 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS277SSS02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS277SSS03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS277SSS04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS277SWH0 ELECTRIC BUILT IN OVEN
Whirlpool KEBS277SWH00 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS277SWH02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS277SWH04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS277SWH1 ELECTRIC BUILT IN OVEN
Whirlpool KEBS277SWH2 ELECTRIC BUILT IN OVEN
Whirlpool KEBS277WAL3
Whirlpool KEBS277WBL3
Whirlpool KEBS277WWH0 Ranges, Electric*
Whirlpool KEBS277WWH1 Ranges, Electric*
Whirlpool KEBS277WWH2 Ranges, Electric*
Whirlpool KEBS277WWH3 Ranges, Electric*
Whirlpool KEBS277XAL0
Whirlpool KEBS277XAL3
Whirlpool KEBS277XBL0 ELECTRIC WALL OVEN
Whirlpool KEBS277XBL2 ELECTRIC WALL OVEN
Whirlpool KEBS277XBL3 ELECTRIC WALL OVEN
Whirlpool KEBS277XWH0 Ranges, Electric*
Whirlpool KEBS277XWH2 Ranges, Electric*
Whirlpool KEBS277XWH3 Ranges, Electric*
Whirlpool KEBS277YAL0 ELEC. WALL OVEN
Whirlpool KEBS277YAL1 ELECTRIC WALL OVEN
Whirlpool KEBS277YAL2 ELECTRIC WALL OVEN
Whirlpool KEBS277YAL3 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS277YAL4 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS277YBL0 ELEC. WALL OVEN
Whirlpool KEBS277YBL1 ELECTRIC WALL OVEN
Whirlpool KEBS277YBL2 ELECTRIC WALL OVEN
Whirlpool KEBS277YBL3 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS277YBL4 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS277YWH0 ELEC. WALL OVEN
Whirlpool KEBS277YWH1 ELECTRIC WALL OVEN
Whirlpool KEBS277YWH2 ELECTRIC WALL OVEN
Whirlpool KEBS277YWH3 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS277YWH4 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS278AAL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBS278ABL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBS278AWH0 Ranges, Electric*
Whirlpool KEBS278AWH1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBS278BAL0 27" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS278BAL1 ELECTRIC BUILT-IN DOUBLE OVEN
Whirlpool KEBS278BAL2 27" ELECTRIC CONVECTION OVEN
Whirlpool KEBS278BAL3 27" ELECTRIC CONVECTION OVEN
Whirlpool KEBS278BBL0 ELECTRIC BUILT-IN DOUBLE OVEN
Whirlpool KEBS278BBL1 SUPERBA 27" ELECTRIC WALL OVEN
Whirlpool KEBS278BBL2 27" ELECTRIC CONVECTION OVEN
Whirlpool KEBS278BBL3 27" ELECTRIC CONVECTION OVEN
Whirlpool KEBS278BWH0 27" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS278BWH1 ELECTRIC BUILT-IN DOUBLE OVEN
Whirlpool KEBS278BWH2 27" ELECTRIC CONVECTION OVEN
Whirlpool KEBS278BWH3 27" ELECTRIC CONVECTION OVEN
Whirlpool KEBS278DBL1 OVEN STOPS WORKING MID-CYCLE-DOUBLE OVENS
Whirlpool KEBS278DBL10 OVEN
Whirlpool KEBS278DBL11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS278DBL2 Built-In Oven, Electric
Whirlpool KEBS278DBL4 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS278DBL6 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS278DBL7 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS278DBL8 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS278DBL9 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS278DBS10 OVEN
Whirlpool KEBS278DBS11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS278DBS6 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS278DBS7 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS278DBS8 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS278DBS9 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS278DSS10 OVEN
Whirlpool KEBS278DSS11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS278DSS6 OVEN
Whirlpool KEBS278DSS7 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS278DSS8 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS278DSS9 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS278DWH1 Built-In Oven, Electric
Whirlpool KEBS278DWH10 OVEN
Whirlpool KEBS278DWH11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS278DWH2 Built-In Oven, Electric
Whirlpool KEBS278DWH4 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS278DWH6 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS278DWH7 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS278DWH8 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS278DWH9 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS278SBL00 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS278SBL02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS278SBL04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS278SSS00 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS278SSS02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS278SSS03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS278SSS04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
  #2 (permalink)
Old 12-09-2008, 09:47 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here is the parts breakdown
Model KEBS277DBL4
Here is the tech sheet in case you do not have it.
https://www.servicematters.com/docs/...%204454771.pdf
Yes: it looks like a slow blow fuse to me, should just pry up out of the holders. Sorry could not find the rating for it. Should be imprinted on the metal ends. If replacing make sure you get slow blow type.
It is always a possibility.
Not sure what you mean by cycling. But if you were flipping the breaker off/on it may have taken the fuse out. This is just a guess because I do not have a schematic of the board.
I would try replacing the fuse first.
Cannot make a call on this depends on how electrically/mechanically inclined you are, what the cost is going to be, do you know of a repair shop with good techs etc etc etc
__________________
  #3 (permalink)
Old 12-09-2008, 09:48 AM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
It could be a number of things.
Here's the breakdown Model KEBS277DBL4
You may want to check the thermal fuse on the back of the unit (#37 on page 3) That is a common part to go out.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kitchenaid subpra went dead while cleaning Tosha1 Oven Repair (including Ranges and Cooktops) 24 08-15-2011 06:30 PM
Dead Kitchenaid Oven bjlidi Oven Repair (including Ranges and Cooktops) 1 07-05-2009 12:48 PM
Kitchenaid dishwasher dead Toroweap Dishwasher Repair 7 06-04-2009 01:38 PM
Kitchenaid Fridge Hummed now dead erickr123 Refrigerator & Freezer Repair 4 11-24-2008 01:25 AM
dead Kitchenaid dishwasher david braun Dishwasher Repair 2 08-27-2008 07:27 PM
