Discuss
pesky Thermador range door won't lock in place
 in
Attempting to reinstall a Thermador range door (customer removed it himself, but couldn't get it back on). No install
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » pesky Thermador range door won't lock in place
  #1 (permalink)
Old 10-15-2007, 11:54 AM
ajappliance ajappliance is offline
Junior Member
ajappliance is on a distinguished road
Default pesky Thermador range door won't lock in place
Model Number: PRSG-366   Brand: Thermador   Age: 5 - 10 years
No install instructions could be found for the 6-7 year old PRSG-366 (36", 6 gas burners). Thermador installation docs on their website seem to show a newer hinge mechanism than this door has.
This oven door has a two-part hinge mechanism. The newer models I've seen before have a one-part hinge.
Doing a bit of research, and after sitting the door in place, it looks like you have to lift the door up hard and push the bottom of the door in. I'm afraid to dent the finish of the door until I'm more sure this is the way to go.
Any suggestions? I won't hold you accountable if I dent the door
- Ray
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Pesky Thermador range door won ajappliance Oven Repair (including Ranges and Cooktops) 0 10-15-2007 11:52 AM
oven door will not lock Dennis Loose Oven Repair (including Ranges and Cooktops) 0 10-08-2007 06:37 PM
Duet door lock problem Fixshannon Washer Repair 0 09-14-2007 09:20 AM
Washer door lock only jefflisa2 Washer Repair 0 08-26-2007 09:31 PM
Door will not lock hossross Washer Repair 0 08-25-2007 10:28 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
