| » Replace glass top for Frigidaire Slide in Electric Stove |
Model Number: PLES389ECC Brand: Frigidaire Age: 5 - 10 years
Broke the top of the stove and need info on how to replace the glass cooktop for a Frigidaire model #PLES389ECC. Thanks
Quote:
Baysedge, Here are excerpts from the service manual, to help you get through this repair, How to access the control panel • Remove the screw on each side. • Remove the two screws under the console. • Pull down the console. Remove the screw on both sides of the console. How to reach the cooktop Surface Elements • Remove the control panel. • Remove the four screws on the front on the burner box (two on both side). • Pull up on the entire burner box and in order reach the surface burner box.elements, just flip over the • Unscrew the burner box from all sides. • Remove the burner box from the glass top. • Remove the retainer bar by applying pressure to the extremity and pulling the anchorage away from the retainer bar in order to free the surface element. *** There is no need to unplug all the elements upon replacing the glass cooktop. *** • Follow these steps backward in order to re-assemble the cooktop and the control panel. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
It was a Protected PDF file, Did you find another problem ? I'll be happy to copy and send you more information, if you'd like.
__________________
No, no problems. I should be able to replace my glass top with info I've found. I just prefer to have as knowledge as possible before I disassemble something for the first time. I found service manuals for older versions of my Frigidaire FES367DSC but they weren't exactly what was looking for. After searching various forums I came across this one, the way you phrased your post made me curious to known if you had access to service manuals that aren't as widely available. If you know of any databases that may contain manuals of the more technical variety(i.e. not the basic ones that come with the stove) related to the above mentioned range pointing me in its direction would be appreciated.
Quote:
I've rechecked, and attempted to copy and attach the manual I used, several times. You may want to contact the manufacturer, and see if they can get you a hard copy, Part number 318202121 , Service manual. Frigidaire 1-800-451-7007
__________________
Ok, Take it easy, Let us know how the repair went, when you're done. Good Luck,
__________________
| Display Modes | |
| GE glass top electric stove | rgotcliffe | Oven Repair (including Ranges and Cooktops) | 0 | 01-17-2011 10:13 AM |
| replace glass stove top | sal19835 | Oven Repair (including Ranges and Cooktops) | 0 | 12-31-2010 08:50 AM |
| Frigidaire Glass STove top | Jane H. | Oven Repair (including Ranges and Cooktops) | 0 | 11-16-2009 06:54 AM |
| glass top replacement for electric frigidaire stove | ronaldgreco@optonline.net | Oven Repair (including Ranges and Cooktops) | 0 | 06-29-2009 07:43 PM |
| replace glass electric stove top | rawsail | Oven Repair (including Ranges and Cooktops) | 0 | 04-11-2009 02:42 PM |
