| » Burners don"t lite |
Model Number: JGBC15GEK1HH Brand: GE Age: More than 10 years
GE gas stovetop burners won't lite,no clicking on any burners.Was told that there is a different ignition on the left than the right.If this is fact,would they both go at the same time seems strange? Please tell me what needs to be replaced and the part #. Thank-You
Quote:
Westport, I don't see a double spark module on the unit. This unit appears to have spark igniters on all the burners, Do you hear the igniters clicking when you turn on the oven ? Here is the part number for the spark module I found, Part number: AP4297622 It's located on the back of the range, so you'll need to slide it out and remove the back panel to access it. When you replace the part, make sure you read the designation label on the old module and connect the wire to the same designation on the new module.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Westport, You could, still have a bad spark module, per the previous post, Based on your post, the oven thermostat ignition switch is working, But, you may have a bad burner ignition switch, or damaged wire, Part number: AP2024236 Do you have a multi meter to check the switch circuits ? The igniter switch circuit should be a closed in the "lite" position, and an open circuit in any other position. You'll need to remove the cooktop and the panel, enclosing the gas burner valves to access the switches and wiring for the burner valves. Good Luck,
__________________
| Display Modes | |
| stovetop burners will not ignite but will lite manually | rhoades3 | Oven Repair (including Ranges and Cooktops) | 1 | 01-21-2009 06:50 AM |
| Kenmore Gas burners and stove will not lite | gloede99 | Oven Repair (including Ranges and Cooktops) | 1 | 10-28-2008 04:59 PM |
| Top burners no longer "spark" & don't lite | William Lidyard | Oven Repair (including Ranges and Cooktops) | 1 | 09-04-2008 10:20 AM |
| Stove top burners will not lite with igniters | 1992bamafan | Oven Repair (including Ranges and Cooktops) | 4 | 02-21-2008 12:10 PM |
| ballas lite above burners wont come on | thehawkfish | Oven Repair (including Ranges and Cooktops) | 0 | 10-27-2007 02:44 PM |
