Discuss
What's a guy to do?
 in
I have a Kitchen Aid double, electric oven. Top is convection. Top ovens heating element will not go on. Was
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » What's a guy to do?
  #1 (permalink)
Old 02-02-2011, 04:10 PM
Junior Member
Lobokitchenaid is on a distinguished road
Default What's a guy to do?
Brand: Kitchen Aid   Age: 1 - 5 years
I have a Kitchen Aid double, electric oven. Top is convection. Top ovens heating element will not go on. Was working fine until last night. While in the cleaning mode our power went out(incredible blizzard). When the power came on this morning it did not return to cleaning mode. When we went to turn the oven on it would not preheat in regular or broiler mode. Any suggestions as far as what it likely is?
Floundering outside Chi-town
Ads By Google
  #2 (permalink)
Old 02-03-2011, 03:34 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
A model number may help others help you.
Model Number Locator
Are you saying that neither element goes on or that just the broiler element is not working?
Also are there any other symptoms/problems?
Many units have a thermal cut-off that kills power to one or both of the elements perhaps this blew. It is usually attached to the back or the top of the oven.
__________________
  #3 (permalink)
Old 02-03-2011, 11:39 AM
Junior Member
Default What's a guy to do #2
The Model number is KEBs277sbl02
There are not any other symptoms aside from neither the element for brolier or regular element will not light. Bottom oven works fine.
Thanks for the idea of the thermal cut-off. Is that something I could do myself and order online? ANy other thoughts as to what that might be?
Thanks so much for the input!
  #4 (permalink)
Old 02-03-2011, 01:10 PM
Senior Expert
APP Volunteer
Default
Replacement parts for WHIRLPOOL KEBS277SBL02 27`` BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION | AppliancePartsPros.com
Here is the tech sheet, see the attachment.
If you decide to tackle it this should help
https://secured.whirlpool.com/Servic...all%20Oven.pdf
The unit does have thermal cutoffs, look in the L2 line of the wiring diagram in the tech sheet.
I cannot comment depends if you are comfortable with it and have some basic DIY skills. Just be sure that power is turned off when working on the unit. If you go to the Whirlpool site you can probably download the install sheet which may also be useful.
and order online?
See the parts
I would try running the diagnostics first.
I would measure it with a meter first just to be sure that it is the problem.
Could be a bad wire or a bad control board but the thermal cut-off would be at the top of my list.
__________________
  #5 (permalink)
Old 02-03-2011, 03:28 PM
Junior Member
Thanks for the good info, you have given me alot to think about and good direction.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
