Discuss
1 Burner doesn't work, and hot surface indicator light stays on
 in
The right rear, dual element burner of my cooktop has ceased working and the hot surface indicator light is staying
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » 1 Burner doesn't work, and hot surface indicator light stays on
  #1 (permalink)
Old 02-02-2011, 03:32 PM
Junior Member
ekleber is on a distinguished road
Question 1 Burner doesn't work, and hot surface indicator light stays on
Model Number: RC8646XDB2   Brand: Whirlpool   Age: More than 10 years
The right rear, dual element burner of my cooktop has ceased working and the hot surface indicator light is staying on. My thinking is the switch to the element went bad, but after reading up, I wondered if it could be the element itself(guessing no because wouldn't one of them still work?) or a wire to the element from the switch. Is the light also staying on some kind of a clue? Maybe it is something else? Speaking of which, I'll bet the wiring diagram would give a clue, but I'm clueless in reading them. Any help appreciated, Ean
Ads By Google
Related Models
Whirlpool RC8646XDB2
Whirlpool RC8646XDQ0
Whirlpool RC8646XDQ1
Whirlpool RC8646XDQ2
Whirlpool RC8646XDZ0
Whirlpool RC8646XDZ1
Whirlpool RC8646XDZ2
Whirlpool RC8700EDB0
Whirlpool RC8700EDW0
Whirlpool RC8720EDB0
Whirlpool RC8720EDW0
Whirlpool RC8800XLH
Whirlpool RC8800XPH
Whirlpool RC8850XRH0
Whirlpool RC8850XRH1
Whirlpool RC8850XRH2
Whirlpool RC8850XRH3
Whirlpool RC8900XAB0
Whirlpool RC8900XAH0
Whirlpool RC8900XAQ0
Whirlpool RC8900XAQ1
Whirlpool RC8900XMH0
Whirlpool RC8900XXB0
Whirlpool RC8900XXQ0
Whirlpool RC8900XXW0
Whirlpool RC8920XAH0
Whirlpool RC8920XRH0
Whirlpool RC8920XRH1
Whirlpool RC8920XRH2
Whirlpool RC8920XRH3
Whirlpool RC8950XRH0
Whirlpool RC8950XRH1
Whirlpool RC8950XRH2
Whirlpool RC8950XRH7
General Electric RCB757WJ1WW Electric range
General Electric RCB787WJ1WW Electric range
General Electric RCB790S J1SA
General Electric RCBS525J1WW Electric range
General Electric RCBS526J1WW Electric range
General Electric RCBS536WJ1WW Electric range
General Electric RCBS540SJ1SA Electric range
General Electric RCBS787WJ1WW Electric range
Amana RCC-10 Mwave - Mounted Over Range/wo
Amana RCC-1010 Walloven - Std Mwave Ele
Amana RCC-3 Range - S/c S/i Ddraft Gas
Amana RCC-3-A Range - S/c S/i Ddraft Gas
Amana RCC-3-A1 Range - S/c S/i Ddraft Gas
Amana RCC-3-AG Range - S/c S/i Ddraft Gas
Amana RCC-3-AG1 Range - S/c S/i Ddraft Gas
Amana RCC-3-C Range - S/c S/i Ddraft Gas
Amana RCC-3-C1 Range - S/c S/i Ddraft Gas
Amana RCC-3-L1 Range - S/c S/i Ddraft Gas
Amana RCC-4 Range - S/c S/i Ddraft Gas
Amana RCC-4-A Range - S/c S/i Ddraft Gas
Amana RCC-4-A1 Range - S/c S/i Ddraft Gas
Amana RCC-4-AG Range - S/c S/i Ddraft Gas
Amana RCC-4-AG1 Range - S/c S/i Ddraft Gas
Amana RCC-4-C Range - S/c S/i Ddraft Gas
Amana RCC-4-C1 Range - S/c S/i Ddraft Gas
Amana RCC-4-L1 Range - S/c S/i Ddraft Gas
Amana RCC-6 Range - S/c S/i Ddraft Gas
Amana RCC10 Walloven - Std Mwave Ele
Amana RCC1020 Walloven - Std Mwave Ele
Whirlpool RCC3024GB0
Whirlpool RCC3024GB1
Whirlpool RCC3024GB2
Whirlpool RCC3024GB3
Whirlpool RCC3024GQ0
Whirlpool RCC3024GQ1
Whirlpool RCC3024GQ2
Whirlpool RCC3024GQ3
Whirlpool RCC3024GT2
Whirlpool RCC3024GT3
Whirlpool RCC3024GZ0
Whirlpool RCC3024GZ1
Whirlpool RCC3024GZ2
Whirlpool RCC3024KB0
Whirlpool RCC3024KQ0
Whirlpool RCC3024KT0
Whirlpool RCC3024LB0
Whirlpool RCC3024LB01 30" Electric Built - in Cooktop
Whirlpool RCC3024LB02 30" Electric Built - in Cooktop
Whirlpool RCC3024LQ0
Whirlpool RCC3024LQ01 30" Electric Built - in Cooktop
Whirlpool RCC3024LQ02 30" Electric Built - in Cooktop
Whirlpool RCC3024LT0
Whirlpool RCC3024LT01 30" Electric Built - in Cooktop
Whirlpool RCC3024LT02 30" Electric Built - in Cooktop
Whirlpool RCC3024RB00 30" Electric Built - in Cooktop
Whirlpool RCC3024RB01 30" Electric Built - in Cooktop
Whirlpool RCC3024RB02 30" Electric Built - in Cooktop
Whirlpool RCC3024RQ00 30" Electric Built - in Cooktop
Whirlpool RCC3024RQ01 30" Electric Built - in Cooktop
Whirlpool RCC3024RQ02 30" Electric Built - in Cooktop
Whirlpool RCC3024RT00 30" Electric Built - in Cooktop
Whirlpool RCC3024RT01 30" Electric Built - in Cooktop
Whirlpool RCC3024RT02 30" Electric Built - in Cooktop
Amana RCC6 Walloven - Std Mwave Ele
Maytag RCE20LA-2A  Ref - Sxs
Maytag RCE20LN-2A  Ref - Sxs
Maytag RCE224RDA  Ref - SXS/I&W
Maytag RCE224RDV  Ref - SXS/I&W
Maytag RCE224TDM Ref - SXS/I&W
Maytag RCE224TDV Ref - SXS/I&W
  #2 (permalink)
Old 02-03-2011, 03:19 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL RC8646XDB2 | AppliancePartsPros.com
The hot surface indicator points toward the infinite switch being the culprit.
Depends where it burns out.
You could check the element with a meter each one should be about 40 to 50 ohms. You may even be able to see if it is nurned out.
Possible but then the light should not come on.
Something else is always a possibility it is a matter of odds.
There are always weird things that may happen.
__________________
  #3 (permalink)
Old 02-03-2011, 12:14 PM
Junior Member
Default
Appreciate the feedback. Is infinite switch the one that turns that element on and off (#15 in parts drawing)? Are element not working and hot surface light continuously on possibly 2 different faults? If so would appreciate possible causes for each. Other three elements working fine. Thanks,
Evan
  #4 (permalink)
Old 02-03-2011, 12:49 PM
Senior Expert
APP Volunteer
Default
No the switches are Item 7 in Section 1.
I believe the one you need is AP3032573 but would confirm this when ordering.
Odds are very high that it is just the switch since both problems showed up at the same time and the switch does control the light.
__________________
  #5 (permalink)
Old 02-04-2011, 09:51 AM
Junior Member
Default
Thank you so much for the knowledge and replies. I'll order the switch. any trick to replacing it besides making sure the power to the cooktop is cut? Thanks,
Evan
  #6 (permalink)
Old 02-04-2011, 10:30 AM
Senior Expert
APP Volunteer
Default
Should be straight for ward.
Either do one wire at a time or make yourself a note of which wire goes where.
You would be surprised how many people disconnect all the wires and then cannot remember where they go.
__________________
  #7 (permalink)
Old 02-04-2011, 10:36 AM
Junior Member
Default
Appreciate the guidance. Thanks again,
Evan
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Surface burner hot light stays on. Nosoup4u Oven Repair (including Ranges and Cooktops) 3 01-09-2011 06:19 AM
hot surface indicator light stays on constantly changty Oven Repair (including Ranges and Cooktops) 0 07-17-2010 05:07 PM
surface indicator light legs Oven Repair (including Ranges and Cooktops) 1 08-23-2009 07:51 PM
Burner doesn't work & hot indicator light stays on joaroe Oven Repair (including Ranges and Cooktops) 2 08-04-2009 08:12 PM
surface indicator light stays on slomotion Oven Repair (including Ranges and Cooktops) 0 05-22-2008 10:30 AM
