Discuss
How to remove cooktop glass and put back?
 in
An old thread, but this thread helped me with the switch repair on my glass top Kenmore (91132355591). I ordered
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » How to remove cooktop glass and put back?
  #11 (permalink)
Old 05-10-2014, 05:39 AM
Junior Member
dkraines is on a distinguished road
Default
An old thread, but this thread helped me with the switch repair on my glass top Kenmore (91132355591). I ordered the switch (WB24T10071). I didn't need the tape.
The burner drip pans attach the burner box to the glass, once I removed those, a gentle pry between the glass and burner box and the burner box easily separated from the glass (it was not glued on one side, but probably sticky from age). I replaced the switch, and lined up the burner box to the drip pans to screw back together.
This was about a 5 to 10 minute repair.
Cheers!
  #12 (permalink)
Old 05-12-2014, 06:04 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Cheers!
Dkraines, Great Job... Thanks for the update, we're glad all went well for you.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #13 (permalink)
Old 06-06-2015, 09:54 AM
Junior Member
OldCH4 is on a distinguished road
Default Old Thread but it helped wth GE Profile Gas Cooktop
I had two problems. I dropped a pan lid and took a chip out of the top. It did not affect function, and I wasn't bothered by it, but SWMBO could not stand it. Also the buner sprark would not stop. So...
I replace the top, the spark generator and the switch harness. The directions here gave me the confidence to do it. All done, works great.
A couple of notes. If you are replacing the top, you will need the burner gaskets. They cannot be salvaged from the old top. There was no seal between the counter and the top, but the top shipped with an insulated heat shield that provided seal to the box. I was a little hesitant pulling off the burners. The ignitor was a little difficult to pull out of the connection, but if you go gently it won't be a problem.
Thanks for your help. SWMBO is happy so we are all happy.
  #14 (permalink)
Old 06-08-2015, 06:29 AM
Senior Expert
Default
OldCH4, Great !!! Glad we could help a little. Good Luck !!!
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
i cant remove the cooktop glass 4u2nv1970 Oven Repair (including Ranges and Cooktops) 0 11-06-2010 11:03 AM
Remove metal frame from glass cooktop? ido59 Oven Repair (including Ranges and Cooktops) 0 02-23-2010 06:00 AM
How do I remove the back? izdani Dryer Repair 1 02-11-2010 05:57 PM
How to remove back FS3434 Refrigerator & Freezer Repair 5 08-01-2009 02:41 PM
remove old destroyed cooktop and install new cooktop richlibl Oven Repair (including Ranges and Cooktops) 4 07-06-2009 10:42 PM
