Discuss
Kitchenaid dual burner on ceramic stovetop will not turn on for the single burner
 in
Our Kitchen Aid dual burner will only work on dual and not on the single setting. We think it is
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kitchenaid dual burner on ceramic stovetop will not turn on for the single burner
  #1 (permalink)
Old 02-01-2011, 11:00 AM
Junior Member
schmidtjl@cni.net is on a distinguished road
Default Kitchenaid dual burner on ceramic stovetop will not turn on for the single burner
Model Number: KESC300HWH4   Brand: Kitchen Aid   Age: 5 - 10 years
Our Kitchen Aid dual burner will only work on dual and not on the single setting. We think it is a switch but are not sure which part exactly since there are a couple different ones. We really need to find out how to remove the existing switch and replace it with a new one. How do we find directions to do that?
Thanks!
Ads By Google
Related Models
Whirlpool KESC300HWH4
Whirlpool KESC300HWH5
Whirlpool KESC300HWH6
Whirlpool KESC300HWH8
Whirlpool KESC307BAL1
Whirlpool KESC307BAL2
Whirlpool KESC307BAL3
Whirlpool KESC307BAL4
Whirlpool KESC307BAL5
Whirlpool KESC307BAL6
Whirlpool KESC307BAL8
Whirlpool KESC307BAL9
Whirlpool KESC307BWH1
Whirlpool KESC307BWH2
Whirlpool KESC307BWH3
Whirlpool KESC307BWH4
Whirlpool KESC307BWH5
Whirlpool KESC307BWH6
Whirlpool KESC307BWH8
Whirlpool KESC307BWH9
Whirlpool KESC307GAL0
Whirlpool KESC307GAL1
Whirlpool KESC307GBL0
Whirlpool KESC307GBL1
Whirlpool KESC307GBS0
Whirlpool KESC307GBS1
Whirlpool KESC307GBT0
Whirlpool KESC307GBT1
Whirlpool KESC307GWH0
Whirlpool KESC307GWH1
Whirlpool KESC307HBL0
Whirlpool KESC307HBL1
Whirlpool KESC307HBL3
Whirlpool KESC307HBL4
Whirlpool KESC307HBL6
Whirlpool KESC307HBL8
Whirlpool KESC307HBS0
Whirlpool KESC307HBS1
Whirlpool KESC307HBS3
Whirlpool KESC307HBS4
Whirlpool KESC307HBS5
Whirlpool KESC307HBS6
Whirlpool KESC307HBS8
Whirlpool KESC307HBT0
Whirlpool KESC307HBT1
Whirlpool KESC307HBT3
Whirlpool KESC307HBT4
Whirlpool KESC307HBT5
Whirlpool KESC307HBT6
Whirlpool KESC307HBT8
Whirlpool KESC307HWH0
Whirlpool KESC307HWH1
Whirlpool KESC307HWH3
Whirlpool KESC307HWH4
Whirlpool KESC307HWH5
Whirlpool KESC307HWH6
Whirlpool KESC307HWH8
Whirlpool KESC307HWW4
Whirlpool KESC307HWW6
Whirlpool KESC307HWW8
Whirlpool KESC308LSS0 30" Slide - in Range Designer Style Convection Oven
Whirlpool KESH307BAL1
Whirlpool KESH307BAL2
Whirlpool KESH307BAL3
Whirlpool KESH307BAL4
Whirlpool KESH307BAL5
Whirlpool KESH307BAL6
Whirlpool KESH307BAL8
Whirlpool KESH307BAL9
Whirlpool KESH307BBL1
Whirlpool KESH307BBL2
Whirlpool KESH307BBL3
Whirlpool KESH307BBL4
Whirlpool KESH307BBL5
Whirlpool KESH307BBL6
Whirlpool KESH307BBL8
Whirlpool KESH307BBL9
Whirlpool KESH307BWH1
Whirlpool KESH307BWH2
Whirlpool KESH307BWH3
Whirlpool KESH307BWH4
Whirlpool KESH307BWH5
Whirlpool KESH307BWH6
Whirlpool KESH307BWH8
Whirlpool KESH307BWH9
Whirlpool KESH307GAL0
Whirlpool KESH307GAL1
Whirlpool KESH307GBL0
Whirlpool KESH307GBL1
Whirlpool KESH307GBS0
Whirlpool KESH307GBS1
Whirlpool KESH307GBT0
Whirlpool KESH307GBT1
Whirlpool KESH307GWH0
Whirlpool KESH307GWH1
Whirlpool KESH307HBL0
Whirlpool KESH307HBL1
Whirlpool KESH307HBL3
Whirlpool KESH307HBL4
Whirlpool KESH307HBL5
Whirlpool KESH307HBL6
Whirlpool KESH307HBS0
Whirlpool KESH307HBS1
Whirlpool KESH307HBS3
Whirlpool KESH307HBS4
Whirlpool KESH307HBS5
Whirlpool KESH307HBS6
Whirlpool KESH307HWH0
Whirlpool KESH307HWH1
Whirlpool KESH307HWH3
Whirlpool KESH307HWH4
Whirlpool KESH307HWH5
Whirlpool KESH307HWH6
Whirlpool KESI901PBL00 30" Slide - in Electric Oven
Whirlpool KESI901PBL01 30" Slide - in Electric Oven
Whirlpool KESI901PBS00 30" Slide - in Electric Oven
Whirlpool KESI901PBS01 30" Slide - in Electric Oven
Whirlpool KESI901PWH00 30" Slide - in Electric Oven
Whirlpool KESI901PWH01 30" Slide - in Electric Oven
Whirlpool KESK901SBL00 30" Slide - in Electric Oven
  #2 (permalink)
Old 02-02-2011, 11:47 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Thanks!
Schmidt,
Based on your post,
Here are some possible part numbers, and the instructions from the service manual, as you requested(some additional info if needed).
Part number: AP3751872
Part number: AP3842098
REMOVING THE CONTROL PANEL,
AN INFINITE SWITCH & BIMETAL SWITCH
Electrical Shock Hazard
Disconnect power before servicing.
Replace all parts and panels before
operating.
Failure to do so can result in death or
electrical shock.
1. Unplug range or disconnect power.
2. Pull the range forward far enough to access
the end cap screws.
3. To remove the control panel:
a) Remove the screw from each end cap.
b) Open the oven door and remove the
three screws from the bottom of the
control panel
c) Lift the front of the control panel, pull it
forward, and slide the front edge of the
cooktop glass out of the slot in the front
of the panel.
d) Rotate the control panel up and over so
the bottom side faces up.
4.To remove an infinite switch:
a) Pull the knob off the switch you wish to
service and remove the nut and fiber
flat washer.
b) Remove the wires from the infinite
switch terminals and remove the switch.
REASSEMBLY NOTE: When reinstalling the
control panel, insert the groove in the front of
the panel over the front edge of the cooktop
glass, and lower it onto the front of the range.
Be careful not to pinch any of the wires between
the front edge of the control panel and
the chassis
REMOVING AN ELEMENT & LIMITER AND
THE HOT SURFACE INDICATOR ASSEMBLY
2. Remove the control panel from its
subchassis,
and rotate it forward onto the cooktop
glass.
3. Remove the five screws and flat washer
from the control panel subchassis
4. Move the control panel back into place
over the chassis, then lift the front of the
cooktop assembly, and prop it up with a
piece of board so that you can access the
components CAUTION: Be careful
that the cooktop does not accidentally fall.
5.To remove an element and limiter:
a) Remove the wires from the element
and limiter terminals.
b) Remove the screw, or pull the end of
the retaining rod out of the bracket, and
remove the element and limiter from
the bottom of the cooktop.
c) Lay the element and limiter on a work
surface. Remove the screws from the
limiter and remove it from the element.
NOTE: Be careful when you remove
the limiter that you do not break the
sensor tube
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Single/dual Burner Wont Turn Off rfox Oven Repair (including Ranges and Cooktops) 0 08-22-2010 01:38 PM
Dual burner has only small burner working bobmorris13@comcast.net Oven Repair (including Ranges and Cooktops) 3 06-03-2010 11:45 PM
short circuit sound when I turn on the burner on a ceramic top nohive Oven Repair (including Ranges and Cooktops) 1 03-15-2010 08:30 PM
kitchenaid dual burner sw wiring memine Oven Repair (including Ranges and Cooktops) 1 06-20-2009 04:58 PM
Stovetop burner out donburrer Oven Repair (including Ranges and Cooktops) 2 04-27-2009 07:26 PM
