Discuss
Thermador gas burner won't ignite
 in
I have a PCS484GGUS Thermador Professional cooktop. Front left burner has had problems for a long time with staying lit.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador gas burner won't ignite
  #1 (permalink)
Old 02-01-2011, 07:57 AM
Junior Member
jrmotter is on a distinguished road
Default Thermador gas burner won't ignite
Brand: Thermador   Age: 5 - 10 years
I have a PCS484GGUS Thermador Professional cooktop. Front left burner has had problems for a long time with staying lit. Burner would frequently go out, igniter would start clicking. Now, it doesn't come on at all and the igniter doesn't make a sound. I don't understand how the system works, so don't know what to look for. All the other burners work fine and have never had a problem.
Ads By Google
  #2 (permalink)
Old 02-15-2011, 07:05 PM
Senior Expert
APP Volunteer
Servicer is on a distinguished road
Default
See this: Thermador range top
The PCS is the cooktop-only version of the PRDS, i.e. the cooktops are the same.
Edit: With your issue, you may also want to measure the resistance of the solenoid, which should be 1760 ohms. The burner dropping out mid-cycle is more indicative of a solenoid over heating and opening up, stopping gas flow. It continues to spark because the spark module is still looking for a flame and tries to re-ignite the burner.
KC
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador simmer burners do not ignite Pino Oven Repair (including Ranges and Cooktops) 6 01-18-2012 04:50 PM
Thermador gas cooktop, 1 burner won't ignite lindam02 Oven Repair (including Ranges and Cooktops) 7 04-04-2011 02:21 PM
Thermador will not ignite and no gas to left burners chawks Oven Repair (including Ranges and Cooktops) 0 06-17-2010 06:55 AM
Thermador cooktop won't ignite bestbitebecky Oven Repair (including Ranges and Cooktops) 1 12-01-2009 04:40 PM
Burner doesn't ignite kurtloth Dryer Repair 3 03-17-2009 04:37 AM
