| » GE oven control module |
Model Number: JTP15wow2ww Brand: GE Age: 5 - 10 years
It appears the control module has gone bad. All lights on the display are on and the controls do not respond to any input.
I show the part number as WB27K5273, to replace the entire control part. Is this the right part and is it available?? Am I diagnosing the problem right? |
Hi droper
The first thing I would recommend to do, before replacing of any parts, is to turn off the circuit breaker for the oven for a few minutes and then turn it back on. Some time reseting the power helps to eliminate a problem. If it did not help then, with the power to the oven off, open the control panel and check the connection of the ribbon from the control panel into the control board. If it did not help either then most likely the problem is a bad control panel, not the control board. - The part number for the new control panel AP2029522 - Here are the break down diagrams for the GE oven Model JTP15WW2WW Good luck. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Just poor quality.
__________________
| Display Modes | |
| Bosch Control Module - programming | WayneK | Washer Repair | 0 | 09-26-2007 04:43 PM |
| Bosch control module | cmsross | Dishwasher Repair | 1 | 09-13-2007 09:42 PM |
| oven control dark | Earlandtrudyg | Oven Repair (including Ranges and Cooktops) | 0 | 08-29-2007 04:11 PM |
| Ge Oven Control | jmajda12 | Oven Repair (including Ranges and Cooktops) | 1 | 08-15-2007 05:19 PM |
| Timer clock module for older Whirlpool oven | webber123456 | Oven Repair (including Ranges and Cooktops) | 1 | 07-22-2007 11:16 PM |
