| » Frigidaire Electric cooktop will not shut off |
Model Number: FEFB78DSK Brand: Frigidaire Age: 1 - 5 years
I have a Frigidaire FEFB78DSK Electric range/ Cooktop. I have a problem with the LEFT Front Burner staying on even after the switch is rotated to Off. I do not recieve any error codes, But tonight I had to Shut the breaker off as I could Not get the element to turn off. It has slowly over the past 2 weeks gotten worse. It ranges from not reacting to lowering the heat, and casuing some burnt food by staying on HIGH power when I have lowered the tempertaure setting on the dail to low, to todays Magic act of having the switch in the off position and the burner Glows full RED for a moment and then goes out , then several seconds later it does the same thing, it repeated this until i shut the breaker fearing what could happen.
SADLY the unit is just about 2 years old. I did notice some arcing with a inspection mirror thru the fins on the back of the stove in the switch area. How can I determine if it is the switch causing the problem Sorry for posting in 2 locations New here Ads By Google Related Models |
Most likely the problem is a bad infinite switch for this burner. The new switch comes with the installation instructions.
- The part number for the infinite switch is AP2591804 Here are the break down diagrams for the Frigidaire range Model FEFB78DSK Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Frigidaire Electric stove/cooktop's element will not shut off | Morris | Oven Repair (including Ranges and Cooktops) | 21 | 06-03-2011 09:53 AM |
| Frigidaire Electric Range and Cooktop | bboustany | Oven Repair (including Ranges and Cooktops) | 14 | 11-18-2009 12:26 PM |
| GE Electric Cooktop - Hot surface light will not shut off | silverms | Oven Repair (including Ranges and Cooktops) | 0 | 11-12-2009 12:33 PM |
| electric burner will not shut down | jrcrawford | Oven Repair (including Ranges and Cooktops) | 1 | 09-09-2008 06:30 PM |
| kitchenaid cooktop won't shut off | jappel2 | Oven Repair (including Ranges and Cooktops) | 7 | 09-08-2008 11:45 AM |
