I have a Whirlpool GBD307PDB1 Over under built oven. The Upper Oven Shutdown Thermal Fuse tests as defective from the circuit board. The tech sheet shows it on the rear inside panel and lists it as ""Front" serviceable, but it is not where show and I can not find it. Do I have to remove the unit and service from the rear?
