help! i have a magic chef range and when i put on the oven i hear a loud buzzing noise from behind the electric control panel on the left side and it seems like the oven is not heating up. the buzzing continues until i hit the clear button. buzzing comes on about 3-5 seconds after turning on oven (or broiler). any ideas?
Originally Posted by: Lorbo213 help! i have a magic chef range and when i put on the oven i hear a loud buzzing noise from behind the electric control panel on the left side and it seems like the oven is not heating up. the buzzing continues until i hit the clear button. buzzing comes on about 3-5 seconds after turning on oven (or broiler). any ideas? Lorbo, Based on your post, I've got a couple of ideas, First and most likely is a failed relay board, located inside the control panel on the left side, Part number: AP4101943
The other possibility(but not likely) is the gas regulator, located on the left side, but down on the bottom frame on the back of the range. Part number: AP4102444
