I have a gas range and the other night the power flicked and now it will not come back on. I have power to the plug but it will not come on. Please help
Originally Posted by: Andrew4020 I have a gas range and the other night the power flicked and now it will not come back on. I have power to the plug but it will not come on. Please help Andrew, I can't get any information on the model number you supplied, Could you re check and make sure, and update us. In general, If the range is a "free standing" gas range(control panel and clock on back of,and above the cooktop, You may have a bad/broken wire, or a bad ERC/Clock. If the range is a "slide in" gas range( control panel, with knobs and ERC/Clock,on the front of the range) you may have an open thermal fuse, a bad/broken wire or ERC/Clock. That's the best I can do for you, until you get a good model number. Good Luck, :) :) :)
The model is 790.7312703 and the serial number is VF83565714. It has the clock on the back and nothing is getting power. Does it have a fuse?
Originally Posted by: Andrew4020 The model is 790.7312703 and the serial number is VF83565714. It has the clock on the back and nothing is getting power. Does it have a fuse? Andrew, That model number still does not come up in my SEARS parts or tech info. But the 790 tells me who made it. With your description and your question, the same applies as my previous post, No there is no inline fuse on the power wires to the display, You'll need to check for damaged wires to the ERC/Clock, if no wires are damaged, you'll need to replace the ERC/Clock. Good Luck, :) :) :)
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
I am sorry I wrote the number down wrong. The serial number is 790.71312703. Will you please look that up and let me know how it can be fixed. The entire unit does not have power, but I can still lite the stovetop with a match. Any help is much appreciated.
Originally Posted by: Andrew4020 I am sorry I wrote the number down wrong. The serial number is 790.71312703. Will you please look that up and let me know how it can be fixed. The entire unit does not have power, but I can still lite the stovetop with a match. Any help is much appreciated. Andrew, Thanks for the update, Are you sure there is 120 VAC at the outlet, that the range is plugged into ? Based on your post, you have no voltage to, or in the range. Do you have a multi meter, so you can check for voltage ? Part number: AP3873826
You can plug a lamp, hair dryer or something, into the outlet and see if that product works. Since you'll most likely have the range moved out, doing that, and if you have voltage,at the outlet, You can remove the rear panel cover, and start looking for a burnt, loose, damaged wire at the terminal block,(where the line cord attaches to the wiring harness behind the back panel, That's when you'll need the multi meter, to check for loss of the 120 VAC, unless there's somthing obvious. :) :) :)
I found the problem, the power cord was burned, so I ordered a new one online and fixed the problem for $25.00.
Now the dishwasher that I just replaced the motherboard in will not drain. The pump makes a strange humming noise, so I ordered a new one and now it does the same thing. What could it be?
The dishwasher is a kenmore model 587.16102800. Thanks
Originally Posted by: Andrew4020 The dishwasher is a kenmore model 587.16102800. Thanks Andrew, Thanks for the model number, You replaced the motherboard and the pump/motor assembly, and the motor only hums ? Part number: AP4512250
Part number: AP4499594
?????? Does the dishwasher fill with water ? Does it drain the water out ? It may be running empty and the hum you hear is the motor running. The drain pump is a separate component, and should drain the unit, wether the pump/motor runs or not. When you had the pump motor out, did you check to see if there was debris,crud in the pump body/housing ? You pretty much coverred most possibilities, with the board and motor. Other than voltage and damaged wires between the two components. You'll need to check and see if you're getting at least 108 VAC at the wiring in the junction box, when the motor is trying to start. Good Luck, :) :) :)
