Discuss
Oven making buzzing noise
 in
I have a 15 year old Magic Chef gas oven/range. The oven hasn't worked in over a year
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven making buzzing noise
  #1 (permalink)
Old 12-06-2008, 09:25 AM
bradNYC bradNYC is offline
Junior Member
bradNYC is on a distinguished road
Default Oven making buzzing noise
Brand: Magic Chef   Age: More than 10 years
I have a 15 year old Magic Chef gas oven/range. The oven hasn't worked in over a year but the broiler and stove burners work fine. There is a constant fan like noise emanating from the oven. I took out the bottom drawer and can see that the noise is coming from the part that the gas line is connected to. It looks like a valve or regulator. Is this something I need to be concerned about? There's no gas smell.
Attached is a photo of the stove and the part that's making the noise.
  #2 (permalink)
Old 12-06-2008, 09:32 AM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Does it make the noise when your using the gas, or is it all the time even when it's off?
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 12-06-2008, 09:35 AM
Junior Member
Default
The noise is all the time even when off.
  #4 (permalink)
Old 12-06-2008, 09:47 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
on that regulator you took the pic of, there is a little lever, move that to the down position and see if the noise stops.
__________________
  #5 (permalink)
Old 12-06-2008, 10:00 AM
Junior Member
Default
Is that definitely a lever? I can't move it.
  #6 (permalink)
Old 12-06-2008, 10:27 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Yep, that is the gas shut off for the oven.
__________________
  #7 (permalink)
Old 12-06-2008, 10:30 AM
Junior Member
Default
Sorry, you're right. I flipped it down but the noise continues.
  #8 (permalink)
Old 12-06-2008, 10:41 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
That is kinda strange, usually a bad regulator will make noise when using gas, and will make that noise if it's leaking gas, but you said you can't smell any gas. The regulator should be replaced, you don't want a gas leak. The other thing you can do to definatly verify that is the noise, is to pull the oven out from the wall and shut of the gas valve at the wall, if the noise persists, then it is something else.
__________________
  #9 (permalink)
Old 12-06-2008, 10:48 AM
Junior Member
Default
Thanks for your help.
  #10 (permalink)
Old 12-06-2008, 12:43 PM
Junior Member
Default
I turned off the gas valve and noise continued. It does seem like it's regulator that's making the noise but I guess it's not the gas. The only way to stop the noise is to unplug the AC.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator/freezer not cooling, making intermittant buzzing noise lcrozier Refrigerator & Freezer Repair 1 09-03-2008 04:11 PM
Kitchen Aid Dishwasher wont run, making loud buzzing noise. Please help! jmoriarty@bellsouth.net Dishwasher Repair 0 02-22-2008 04:53 PM
Refrigerator buzzing noise boo_liya Refrigerator & Freezer Repair 0 11-09-2007 12:25 PM
Whirlpool undercounter oven fan making a lot of noise BakerSam Oven Repair (including Ranges and Cooktops) 0 10-22-2007 08:20 PM
Gibson Upright Freezer making loud buzzing noise..... kakizie Refrigerator & Freezer Repair 0 08-02-2007 04:42 PM
