Discuss
Oven keeps heating
 in
Roper range/oven given to us, seems to be working fine, then issues 2 error codes out of the blue -
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven keeps heating
  #1 (permalink)
Old 10-13-2007, 11:46 AM
rowilson rowilson is offline
Junior Member
rowilson is on a distinguished road
Default Oven keeps heating
Model Number: Part#8522379   Brand: Roper   Age: 1 - 5 years
Roper range/oven given to us, seems to be working fine, then issues 2 error codes out of the blue - F3 and E2 (i think), realized the oven is heating up even though we did not turn it on. Any thoughts out there? Thanks
Rose
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-14-2007, 12:41 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi rowilson
In order to provide you with the most accurate information I need the complete model number of the range. You can fins it on the oven door frame or on the frame behind the bottom drawer. The model number you provided is incorrect.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 10-14-2007, 02:29 PM
Junior Member
Default model info
Thanks Gene
model #FES330KQ
Serial #RL3022463
Rose
  #4 (permalink)
Old 10-14-2007, 05:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Rose
The problem with your oven caused by the shorted "Bake" relay on the Electronic Range Control (ERC). To fix it the ERC has to be replaced.
Also check the resistance on the oven temperature sensor. At the room temperature it suppose to be about 1100 Ohms. If the reading is different the oven temperature sensor has to be replaced too.
- Here are the break down diagrams for the Roper range Model FES330KQ0
- The part number for the new black ERC AP2989925
- The part number for the new white ERC AP3085712
- The part number for the new oven temperature sensor AP3081560
Good luck.
__________________
  #5 (permalink)
Old 10-16-2007, 01:43 PM
Junior Member
Default
Thanks for all your help. in the meantime, is there anyway to just disconnect the oven part so that the stovetop can be used? Thanks
Rose
  #6 (permalink)
Old 10-16-2007, 07:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Rose
Yes, you can do it. Remove the power from the range, open the control panel and disconnect wires from the Bake and Broil terminals on the control board. Remember which wire were goes. Insulate the wires. Assemble the control panel back and restore the power.
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag oven not heating moongidget Oven Repair (including Ranges and Cooktops) 1 02-22-2008 09:05 AM
Range top and oven heating Emily Oven Repair (including Ranges and Cooktops) 1 09-14-2007 11:07 PM
Oven will not stop heating RBowman Oven Repair (including Ranges and Cooktops) 1 09-10-2007 07:13 PM
Oven not heating properly harry-homeowner Oven Repair (including Ranges and Cooktops) 1 08-04-2007 11:44 PM
oven not heating ljticeman Oven Repair (including Ranges and Cooktops) 1 08-01-2007 04:52 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
