| » Hardwick Smooth Top Stove/thermostat |
Model Number: EPG9-77 Brand: Hardwick Age: More than 10 years
My Hardwick Smooth Top (Magic Chef product, bought in April, 1992) serial # 52C137715027 oven would not heat. I replaced the oven heating unit w/ one I ordered from AppliancePartsPros.com but it heats only to 250 degrees. No fuse is bad as far as I can see. I think I need a new thermostat. Can I order that, and does it come w/ installation instructions? If so, what does it cost? Thank you for help.
Pat Lea T. Ads By Google Related Models |
Quote:
Pat, You don't have a thermostat on your range, you have an ERC/clock. (And that part has been discontinued by the manufacturer) But, lets try a couple of things first. Do the cooktop burners work properly ? Check and make sure both breakers in the breaker panel are set and locked in place. *** turn off the power to the range*** You'll need to slide the range out and remove the back panel, so you can check for any damaged, loose wires going to both of the elements, and the oven temp sensor connector for the same. If everything looks and checks OK, You'd want to test the oven temperature sensor with a multi meter(1050 to 1100 ohms at room temperature) or replace it, Part number: AP4009009
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Quote:
Pat, I've searched several of our repair parts sources, And am unable to find an available part, or a substitute part that will work in your unit. Your manufacturing part number is : 7601P175-60 You may want to check other appliance parts sources in your area, or the internet for antique / old parts for a replacment control.
__________________
| Display Modes | |
| Jenn-Air smooth top stove quit working - tripped the breaker | clu1945 | Oven Repair (including Ranges and Cooktops) | 0 | 03-15-2010 09:32 PM |
| Hardwick Stove Top Ignition Module | turbomutt | Oven Repair (including Ranges and Cooktops) | 13 | 06-11-2009 08:46 AM |
| replacing small burner element of smooth top stove | CERushing | Oven Repair (including Ranges and Cooktops) | 0 | 05-09-2009 09:15 AM |
| Cracked Smooth Stove Top | Joe.Lasky@ucdenver.edu | Oven Repair (including Ranges and Cooktops) | 0 | 03-01-2009 05:34 PM |
| smooth top stove - burner not heating and oven noise | efagnan | Oven Repair (including Ranges and Cooktops) | 3 | 12-06-2007 05:04 PM |
