Discuss
apomella
 in
My oven will not turn on for at least 30 to 60 minutes. The stove tops work. I have had
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » apomella
  #1 (permalink)
Old 01-25-2011, 05:56 AM
Junior Member
apomella is on a distinguished road
Default apomella
Model Number: ARDS801E   Brand: Amana   Age: More than 10 years
My oven will not turn on for at least 30 to 60 minutes. The stove tops work. I have had the lower oven bake element checked, and was told it was OK. Any suggestions for parts replacement or repairs?
Ads By Google
Related Models
Amana ARDS801E Range - S/c S/i Ddraft Ele
Amana ARDS801WW Range - S/c S/i Ddraft Ele
Amana ARDS802E Range - S/c S/i Ddraft Ele
Amana ARDS802SS Range - S/c S/i Ddraft Ele
Amana ARDS802WW Range - S/c S/i Ddraft Ele
Amana ARE14 Misc / Accessory
Amana ARE640 Range - S/c S/i Ddraft Gas
Amana ARE650 Range - S/c S/i Ddraft Gas
Amana ARG3600L Range - S/i Std Gas
Amana ARG3600LL Range - S/c S/i Ddraft Gas
Amana ARG3600W Range - S/c S/i Ddraft Gas
Amana ARG3600WW Range - S/c S/i Ddraft Gas
Amana ARG3601L Range - S/c S/i Ddraft Gas
Amana ARG3601LL Range - S/c S/i Ddraft Gas
Amana ARG3601W Range - S/c S/i Ddraft Gas
Amana ARG3601WW Range - S/c S/i Ddraft Gas
Whirlpool ARG483WP01
Whirlpool ARG490
Whirlpool ARG4901
Amana ARG7102C Range - S/c S/i Ddraft Gas
Amana ARG7102L Range - S/c S/i Ddraft Gas
Amana ARG7102W Range - S/c S/i Ddraft Gas
Amana ARG7200L Range - S/c S/i Ddraft Gas
Amana ARG7200W Range - S/c S/i Ddraft Gas
Amana ARG7202 E Range - S/c S/i Ddraft Gas
Amana ARG7300LL Range - S/c S/i Ddraft Gas
Amana ARG7300W Range - S/c S/i Ddraft Gas
Amana ARG7300WW Range - S/c S/i Ddraft Gas
Amana ARG7301L Range - S/c S/i Ddraft Gas
Amana ARG7301LL Range - S/c S/i Ddraft Gas
Amana ARG7301W Range - S/c S/i Ddraft Gas
Amana ARG7301WW Range - S/c S/i Ddraft Gas
Amana ARG7302CC Range - S/c S/i Ddraft Gas
Amana ARG7302LL Range - S/c S/i Ddraft Gas
Amana ARG7302WW Range - S/c S/i Ddraft Gas
Amana ARG7303CC Range - S/c F/s Gas
Amana ARG7303LL Range - S/c F/s Gas
  #2 (permalink)
Old 01-25-2011, 07:01 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Does the broil element work?
Most unit use both elements during a preheat cycle.
Usually they switch back and forth between the two.
This provides a more consistent temperature profile in the oven.
__________________
  #3 (permalink)
Old 01-25-2011, 08:46 AM
Junior Member
Default
Both the bake and broiler elements do not turn on, the oven does not begin to warm for a minimum of approximately 30 minutes, and sometimes as long as 60 minutes to begin heating.
  #4 (permalink)
Old 01-25-2011, 03:47 PM
Junior Member
Default
The broil element does not work either. I press the bake button, and set the temperature. The digital display then shows on, and the temperature stays at 100 degrees. I check the elements which do not get even warm. Maybe after 30 to 60 minutes the bake element finally heats up. As of last nite and tonite, we have given up waiting over an hour with no heat.
  #5 (permalink)
Old 01-26-2011, 07:04 AM
Senior Expert
APP Volunteer
Default
Replacement parts for ARDS801E models | AppliancePartsPros.com
Here is a manual, see attachment.
Your problem is a real puzzler because it does eventually heat up.
I would check the thermal hi-limit switch/thermostat for the elements.
It should be 0 ohms.
If it has any resistance I would replace it.
Check to any loose or overheated connections in the element circuitry.
If all this checks out OK then the only thing I can think of is that the control board is doing something crazy.
__________________
  #6 (permalink)
Old 01-27-2011, 04:35 AM
Junior Member
Default
Thank you very much for the help. I will try your suggestion
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
