Discuss
Replacing the relay panel
 in
I have a maytag electric oven/range. The oven won't bake. The element is not the issue it is fine. It
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Replacing the relay panel
  #1 (permalink)
Old 12-05-2008, 11:29 AM
Junior Member
Vince38 is on a distinguished road
Default Replacing the relay panel
Model Number: CRE805   Brand: Maytag   Age: More than 10 years
I have a maytag electric oven/range. The oven won't bake. The element is not the issue it is fine. It is not giving any codes, but after messing around with a multi meter and doing a couple of tests. (ie. plugging in the broiler wire to the bake plug on the relay board, and it worked) I think the relay board is out on my stove. You all have one in stock, it looks a little different than the one I have in my stove. Yours looks more compact, mine is longer.
Anyway, what do I need to look out for in this job? Where are the pit falls in this and what am I over looking in your opinion. What is the best way to do this, and will the new smaller board work in my stove its like a 1993 model I think.
Vince
Ads By Google
Related Models
Maytag CRE805 Range - S/c F/s Ele
Maytag CRE8400ACL Range - F/s Std Ele
Maytag CRE8400ACW Range - F/s Std Ele
Maytag CRE8400BCL Range - F/s Std Ele
Maytag CRE8400BCW Range - F/s Std Ele
International CRE8400BGL Range - F/s Std Ele
International CRE8400BGW Range - F/s Std Ele
Maytag CRE8600ACL Range - S/c F/s Ele
Maytag CRE8600ACW Range - S/c F/s Ele
Maytag CRE8600BCL Range - S/c F/s Ele
Maytag CRE8600BCW Range - S/c F/s Ele
Maytag CRE8600CCB Range - S/c F/s Ele
Maytag CRE8600CCE Range - S/c F/s Ele
Maytag CRE8600CCL Range - S/c F/s Ele
Maytag CRE8600CCM Range - S/c F/s Ele
Maytag CRE8600CCW Range - S/c F/s Ele
Maytag CRE8700ADE Range - S/c F/s Ele
Maytag CRE8700ADL Range - S/c F/s Ele
Maytag CRE8700ADW Range - S/c F/s Ele
Maytag CRE8700BDE Range - S/c F/s Ele
Maytag CRE8700BDL Range - S/c F/s Ele
Maytag CRE8700BDW Range - S/c F/s Ele
Maytag CRE8700CDE Range - S/c F/s Ele
Maytag CRE8700CDL Range - S/c F/s Ele
Maytag CRE8700CDW Range - S/c F/s Ele
Maytag CRE8700DDE Range - S/c F/s Ele
Maytag CRE8700DDM Range - S/c F/s Ele
Maytag CRE883 Range - S/c F/s Ele
Maytag CRE900 Range - S/c F/s Ele
Maytag CRE905 Range - S/c F/s Ele
Maytag CRE9300BCW Range - S/c F/s Ele
Maytag CRE9300CCL Range - S/c F/s Ele
Maytag CRE9300CCW Range - S/c F/s Ele
Maytag CRE9400ACE Range - S/c F/s Ele
Maytag CRE9400ACL Range - S/c F/s Ele
Maytag CRE9400ACW Range - S/c F/s Ele
Maytag CRE9400BCE Range - S/c F/s Ele
Maytag CRE9400BCL Range - S/c F/s Ele
Maytag CRE9400BCM Range - S/c F/s Ele
Maytag CRE9400BCW Range - S/c F/s Ele
Maytag CRE9400CCB Range - S/c F/s Ele
Maytag CRE9400CCE Range - S/c F/s Ele
Maytag CRE9400CCL Range - S/c F/s Ele
Maytag CRE9400CCM Range - S/c F/s Ele
Maytag CRE9400CCW Range - S/c F/s Ele
Maytag CRE9500ACE Range - S/c F/s Ele
Maytag CRE9500ACL Range - S/c F/s Ele
Maytag CRE9500ACW Range - S/c F/s Ele
Maytag CRE9500ADE Range - S/c F/s Ele
Maytag CRE9500ADL Range - S/c F/s Ele
Maytag CRE9500ADW Range - S/c F/s Ele
Maytag CRE9500BCE Range - S/c F/s Ele
Maytag CRE9500BCL Range - S/c F/s Ele
Maytag CRE9500BCW Range - S/c F/s Ele
Maytag CRE9500BDE Range - S/c F/s Ele
Maytag CRE9500BDL Range - S/c F/s Ele
Maytag CRE9500BDW Range - S/c F/s Ele
Maytag CRE9500CCE Range - S/c F/s Ele
Maytag CRE9500CCM Range - S/c F/s Ele
Maytag CRE9500CDE Range - S/c F/s Ele
Maytag CRE9500CDL Range - S/c F/s Ele
Maytag CRE9500CDW Range - S/c F/s Ele
Maytag CRE9500DDE Range - S/c F/s Ele
Maytag CRE9500DDM Range - S/c F/s Ele
Maytag CRE9530BCB Range - S/c F/s Ele
Maytag CRE9530BCE Range - S/c F/s Ele
Maytag CRE9530BCM Range - S/c F/s Ele
Maytag CRE9530CDE Range - S/c F/s Ele
Maytag CRE9530CDM Range - S/c F/s Ele
Maytag CRE955 Range - S/c F/s Ele
Maytag CRE9590CCL Range - S/c F/s Ele
Maytag CRE9590CCW Range - S/c F/s Ele
Maytag CRE9600ACE Range - S/c F/s Ele
Maytag CRE9600ACL Range - S/c F/s Ele
Maytag CRE9600ACW Range - S/c F/s Ele
Maytag CRE9600ADE Range - S/c F/s Ele
Maytag CRE9600ADL Range - S/c F/s Ele
Maytag CRE9600ADW Range - S/c F/s Ele
Maytag CRE9600BCE Range - S/c F/s Ele
Maytag CRE9600BCL Range - S/c F/s Ele
Maytag CRE9600BCW Range - S/c F/s Ele
Maytag CRE9600CCE Range - S/c F/s Ele
Maytag CRE9600CCM Range - S/c F/s Ele
Maytag CRE9600CDE Range - S/c F/s Ele
Maytag CRE9600CDL Range - S/c F/s Ele
Maytag CRE9600CDW Range - S/c F/s Ele
International CRE9600CGE Range - S/c F/s Ele
Maytag CRE9600DDE Range - S/c F/s Ele
Maytag CRE9600DDM Range - S/c F/s Ele
Maytag CRE9700ACB Range - S/c F/s Ele
Maytag CRE9700ACE Range - S/c F/s Ele
Maytag CRE9700ADB Range - S/c F/s Ele
Maytag CRE9700ADE Range - S/c F/s Ele
Maytag CRE9800ACB Range - S/c F/s Ele
Maytag CRE9800ACE Range - S/c F/s Ele
Maytag CRE9800ADB Range - S/c F/s Ele
Maytag CRE9800ADE Range - S/c F/s Ele
Maytag CRE9800BCB Range - S/c F/s Ele
Maytag CRE9800BCE Range - S/c F/s Ele
Maytag CRE9800CCB Range - S/c F/s Ele
Maytag CRE9800CCE Range - S/c F/s Ele
Maytag CRE9800CCM Range - S/c F/s Ele
Maytag CRE9800CDB Range - S/c F/s Ele
Maytag CRE9800CDE Range - S/c F/s Ele
Maytag CRE9800DDB Range - S/c F/s Ele
Maytag CRE9800DDE Range - S/c F/s Ele
Maytag CRE9800DDM Range - S/c F/s Ele
Maytag CRE9830BCB Range - S/c F/s Ele
Maytag CRE9830BCE Range - S/c F/s Ele
Maytag CRE9830BCM Range - S/c F/s Ele
Maytag CRE9830CDB Range - S/c F/s Ele
Maytag CRE9830CDE Range - S/c F/s Ele
Maytag CRE9830CDM Range - S/c F/s Ele
Maytag CRE9900ACB Range - S/c F/s Ele
Maytag CRE9900ACE Range - S/c F/s Ele
Admiral CREA200ACL Range - F/s Std Ele
Admiral CREA200ACW Range - F/s Std Ele
Admiral CREA300ACL Range - F/s Std Ele
Admiral CREA300ACW Range - F/s Std Ele
Admiral CREA400ACL Range - F/s Std Ele
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help replacing power relay grapes Oven Repair (including Ranges and Cooktops) 10 12-31-2012 01:59 PM
Replacing the ice maker door relay. Palsco1 Refrigerator & Freezer Repair 1 02-21-2010 02:59 PM
Help Replacing Start Relay on Whirlpool Refrigerator bigrob3030 Refrigerator & Freezer Repair 0 06-23-2009 05:28 PM
replacing start relay ccolonnades Refrigerator & Freezer Repair 1 05-28-2009 12:45 PM
Replacing starter/relay with substitution part not2bwutevr Refrigerator & Freezer Repair 1 04-10-2009 03:24 PM
