I can't find any info on a model number at all.. My Igniter is on the way out on Friday it took 10 min for the oven to heat up to my set temp. Anyways all I know is it's a White-Westinghouse and I posted here the wire diagram from the back of the oven but that's all I have here.. I've never seen a igniter like this one before. not sure of the age so I put 5-10 years SubaruB4 attached the following image(s):
nevermind i figured out myself
