| » Electronic clock not working |
Model Number: svd48600w Brand: Jenn-Air Age: 5 - 10 years
My oven controls seem to be working but the LED clock is blank. How hard is it to replace the clock on the Jenn-Air SVD48600. Also the cooling fan runs shortly after the oven is turned on and stays running long after the oven is off. I suspect a thermal switch is failed. can anyone help and advise.
Thanks.....Zirk12 |
I Just Replaced My Clock/timer Circuit Board In My Jenn Air D 156 Because It Was Intermittent Mostly Mittent, It Was An Easy Repair Once I Figured How To Get Into The Panel. 4 Small Screws Underneath And A Part Order From Appliancepartspros.com. If You Have No Clock But The Other Displays On The Same Display Work, The New Board Should Fix The Problem, I Have Replaced The Circuit Board Display On My D 156, And I Have The Same Problem, Mine Would Come On When You Slammed The Overn Door Sometimes. There Is A Short Somewhere In Our Oven, A Random Pounding On The Top Surface Will Recover Our Display For A Short Time, Long Enought To Set The Thermostat.... A Little Funkky When You Have House Guest. I Will Not Give Up To My Discredit.
| Display Modes | |
| Electronic Control Part 2307028 | belmore | Refrigerator & Freezer Repair | 4 | 01-14-2008 08:14 PM |
| Dishwasher N/F; Electronic Control Replaced | Strong | Dishwasher Repair | 0 | 09-20-2007 08:29 PM |
| mixer - electronic conversion 110 -220 | chrisssy | General Talk | 1 | 08-30-2007 02:34 PM |
| Electronic Oven Control | andye | Oven Repair (including Ranges and Cooktops) | 3 | 08-01-2007 08:45 AM |
| electric range/oven clock not working | 50fbn | Oven Repair (including Ranges and Cooktops) | 1 | 07-21-2007 12:47 AM |
