Discuss
Electronic clock not working
 in
My oven controls seem to be working but the LED clock is blank. How hard is it to replace the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Electronic clock not working
  #1 (permalink)
Old 10-13-2007, 08:27 AM
zirk12 zirk12 is offline
Junior Member
zirk12 is on a distinguished road
Default Electronic clock not working
Model Number: svd48600w   Brand: Jenn-Air   Age: 5 - 10 years
My oven controls seem to be working but the LED clock is blank. How hard is it to replace the clock on the Jenn-Air SVD48600. Also the cooling fan runs shortly after the oven is turned on and stays running long after the oven is off. I suspect a thermal switch is failed. can anyone help and advise.
Thanks.....Zirk12
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-27-2008, 11:32 AM
BAHENDRICKS BAHENDRICKS is offline
Junior Member
BAHENDRICKS is on a distinguished road
Default
I Just Replaced My Clock/timer Circuit Board In My Jenn Air D 156 Because It Was Intermittent Mostly Mittent, It Was An Easy Repair Once I Figured How To Get Into The Panel. 4 Small Screws Underneath And A Part Order From Appliancepartspros.com. If You Have No Clock But The Other Displays On The Same Display Work, The New Board Should Fix The Problem, I Have Replaced The Circuit Board Display On My D 156, And I Have The Same Problem, Mine Would Come On When You Slammed The Overn Door Sometimes. There Is A Short Somewhere In Our Oven, A Random Pounding On The Top Surface Will Recover Our Display For A Short Time, Long Enought To Set The Thermostat.... A Little Funkky When You Have House Guest. I Will Not Give Up To My Discredit.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electronic Control Part 2307028 belmore Refrigerator & Freezer Repair 4 01-14-2008 08:14 PM
Dishwasher N/F; Electronic Control Replaced Strong Dishwasher Repair 0 09-20-2007 08:29 PM
mixer - electronic conversion 110 -220 chrisssy General Talk 1 08-30-2007 02:34 PM
Electronic Oven Control andye Oven Repair (including Ranges and Cooktops) 3 08-01-2007 08:45 AM
electric range/oven clock not working 50fbn Oven Repair (including Ranges and Cooktops) 1 07-21-2007 12:47 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
