Discuss
Oven Control Panel
 in
My Frigidaire electric range does not have any display on the contol panel. I checked the incoming power with my
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Control Panel
  #1 (permalink)
Old 12-04-2008, 06:04 PM
Stan Peter Stan Peter is offline
Junior Member
Stan Peter is on a distinguished road
Question Oven Control Panel
Model Number: FEF376ASJ   Brand: Frigidaire   Age: 1 - 5 years
I checked the incoming power with my volt meter, and I have 240 volts at the pigtail connection. The surface elements do work. I have no display on the control panel and the oven does not work.
Do I need to replace the control panel, or do I need to check out something else?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-05-2008, 04:10 AM
denman denman is offline
Senior Expert
APP Volunteer
denman is on a distinguished road
Default
Here is your parts breakdown
Model FEF376ASJ
I would also check that you have 120 volts Neutral to L1 and Neutral to L2.
Board electronics usually run of of 120 volts.
Though if the indicator lights work they usually use the same side of the line as the control board.
If above OK odds are high that you need a new timer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven control panel GLENNA CAGLE Oven Repair (including Ranges and Cooktops) 8 10-01-2008 02:50 PM
replacing oven control panel brad Oven Repair (including Ranges and Cooktops) 2 07-14-2008 02:55 PM
oven control panel indicates LOCKED TrishK Oven Repair (including Ranges and Cooktops) 1 05-19-2008 01:05 PM
Control Panel Assembly for GE Oven cbarker79 Oven Repair (including Ranges and Cooktops) 0 12-29-2007 05:26 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
