I'm trying to replace Rotary Switch PCB, p/n 82874. I have difficulty to handle 4 screws: regular socket ranch is not catching it. Do I need a special ranch or a 6-pronge screwdriver? Thanks.
they could be torx screws #15 is the most popular size but I'm not getting your drift on what kind they are most appliances nowadays have gone to torx
What "drift" would you need? It is close to a 1/8" socket ranch size. I guess, to try your torx #15 idea I should by a special ranch? Are they available at hardware stores? thanks.
Originally Posted by: ValV a special ranch? I'm sorry...it's wrench. A ranch is where Texans raise cattle.
Thank you for the correction of my spelling. It doesn't solve the issue, but still - thanks. So now it is - do I need a special wrench for those screws?
If the screw head has a hollow which looks like a star with 6 points you need a Torx wrench. They are available at hardware and auto supply stores. May have to shop around as some places want an arm and a leg.
One thing to note is some of these screw heads also have a post sticking up in the middle of the star as an extra security device. If your screws have this be sure to get a torx set that has a hole in the center to fit over and down on this post.
PS Hope the weather is nice in Texas as I am freezing my you know what off. 20 below tonight with the wind chill. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman If the screw head has a hollow which looks like a star with 6 points you need a Torx wrench. They are available at hardware and auto supply stores. May have to shop around as some places want an arm and a leg.
PS Hope the weather is nice in Texas as I am freezing my you know what off. 20 below tonight with the wind chill. Thanks for the torx wrench advice - I'll try it this way. I feel your pain with the wind and chill, though not hugely much: in Chicago it is snowy, but pretty mild so far. Thanks again.
