Discuss
Top Burners blow out when oven is on
 in
I have a fridgidare gas range. When the oven is on, the top burners blow out (like they dont have
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Top Burners blow out when oven is on
  #1 (permalink)
Old 01-22-2011, 09:10 AM
Junior Member
tmeyer is on a distinguished road
Default Top Burners blow out when oven is on
Brand: Frigidaire   Age: 5 - 10 years
I have a fridgidare gas range. When the oven is on, the top burners blow out (like they dont have enough air). The range and top work great when only using one at a time. Any Ideas?
Ads By Google
  #2 (permalink)
Old 01-23-2011, 11:34 AM
Junior Member
Default
Gas valve is good, regulator is good. Adjusted oven flame (lower) and still same result.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Bad, Can I use Burners? mikeamondo Oven Repair (including Ranges and Cooktops) 1 12-13-2010 11:20 AM
Surface Burners work OK, Oven dead, no control light turns on for oven Whirlyone Oven Repair (including Ranges and Cooktops) 0 06-07-2010 07:24 AM
Oven broiler and burners work - oven will not heat fatbuford Oven Repair (including Ranges and Cooktops) 0 11-27-2009 05:50 AM
Oven burners not getting gas bisco Oven Repair (including Ranges and Cooktops) 1 11-18-2008 09:29 PM
Burners & Oven both seem to not be getting enough gas. jason in WI Oven Repair (including Ranges and Cooktops) 6 06-17-2008 01:13 PM
