Hi: The DLB relay keeps failing. Replaced it once, lasted several months. Replaced again lasted a few weeks. Replaced clock / touch pad control board and relay and relay lasted a few days. Appliance repair tech came out and replaced the relay, everything checked okay but the relay blew again after only one use. The tech came again and replaced the hi-limit thermostat, fan switch and the relay again but the relay blew after only a couple of uses. When the relay blows, there is only 110v to oven elements. Does this make sense? If the relay blows why would there be any voltage at all? What else could there be left to replace? Could a shorting wire that only happens once in a while be the cause? Everything looks good as far as the power coming in to the main terminal on the oven. Any advice appreciated. Thanks
