Hello, my front left simmer (most used) burner suddenly stopped working. Igniter sparks fine, but there is no flow of gas through jet. Visually, jet is clean and not clogged with food. Audible, I do not hear the "click" that the other three working burners produce to allow the gas to flow. Don't see any loose wires.
Possibility: Valve body (not manufactured anymore), Valve grill safety or Jet valve body or part within holder.
Thank you
