Truman99
#1 Posted : Wednesday, December 3, 2008 5:51:21 PM(UTC)
Truman99
Hi one of the ignitors on one of my burners cracked. I ordered the part and started the replacement process. On this model you have to remove all of the burner screws before you can lift the range top. One by one the screw heads are breaking off, leaving the remainder of the screw in the burners. I stopped at 4 of 12 screws. Do I have to order new burners or can I drill the broken studs and easy out them? Any other suggestions would be appreciated.
#2 Posted : Thursday, December 4, 2008 5:35:26 PM(UTC)
There is nothing to loose. Try to drill them out and if it would not work, order the new burners.
Here are the break down diagrams for the Frigidaire range Model FGF378WCCA
Burner ignitor replacement on Frigidaire stove (Oven Repair (including Ranges and Cooktops))
by kurb 3/1/2010 12:33:26 PM(UTC)
