Discuss
Wedgewood -- oven too hot
 in
Hi, The oven thermostat on my antique Wedgewood stove is out of calibration -- if I set it to 300,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Wedgewood -- oven too hot
  #1 (permalink)
Old 01-18-2011, 06:30 PM
Junior Member
mykle is on a distinguished road
Default Wedgewood -- oven too hot
Brand: -other-   Age: More than 10 years
The oven thermostat on my antique Wedgewood stove is out of calibration -- if I set it to 300, i get 350; if i set it to 350 I get 450. Those numbers are reliable -- i actually have a conversion chart I use to set the temperature accurately. With that chart, I've put off fixing this for ten years. (Clever or stupid? I'm not sure.)
If I pull off the oven knob I find a calibration adjustment underneath, but it's already cranked all the way to "lo". if I turn it the other way, everything gets hotter. I need things cooler, not hotter.
The thermostat is a Robertshaw Model BJ. I could replace it but they're $pendy.
It occurred to me that if I were to (very carefully) crimp the copper temperature sensing bulb a little bit with some pliers, that could increase the pressure in the tube & thereby trigger the thermostat's action at a colder temperature. Is that a dumb idea?
Any advice would be much appreciated. It's an old stove, but other than this one problem it sure works great.
Thanks,
-mykle-
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn Aire Micro/Oven combo, oven door does not shut tight dsazama Oven Repair (including Ranges and Cooktops) 5 03-13-2012 11:29 AM
Dacor Double Wall Oven-replace lower oven relay board CatsR Oven Repair (including Ranges and Cooktops) 3 01-28-2011 07:29 AM
27" electric double oven self clean w/erc111 & upper convection oven sksmith Oven Repair (including Ranges and Cooktops) 0 12-22-2010 06:08 PM
Surface Burners work OK, Oven dead, no control light turns on for oven Whirlyone Oven Repair (including Ranges and Cooktops) 0 06-07-2010 07:24 AM
