Discuss
Error F2-E1
 in
I recently ordered and replaced from here the interior oven glass door. Instead of doing it myself I ended up
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Error F2-E1
  #1 (permalink)
Old 01-18-2011, 03:46 PM
Junior Member
willsfamily4 is on a distinguished road
Default Error F2-E1
Model Number: KESc307hbs8   Brand: Kitchen Aid   Age: 5 - 10 years
I recently ordered and replaced from here the interior oven glass door. Instead of doing it myself I ended up hiring a repair person because KitchenAid told me it was important to get the gaskets in right etc. or it could cause other problems. They said the work would be guaranteed in case something else happened. Now 2 days later I am getting this Error F2-E1 message. When I looked it up online it said "F2 - E1 Keypad cable unplugged"
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock
Can they be related or not? I want to check to see if I need a new control panel but do I have to slide the unit out to access the panel or can I get access to it without doing that. I found instructions on checking the unit but not how to get to the panel.
I appreciate your help. I think I can replace this myself if I have to, but need help figuring out how to get to the control panel before I start. These are the instructions that I found here regarding checking the control panel
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Ads By Google
Related Models
Whirlpool KESC307HBS8 ELECTRIC RANGE
Whirlpool KESC307HBT0 ELECTRIC SLIDE-IN RANGE
Whirlpool KESC307HBT1 ELECTRIC RANGE
Whirlpool KESC307HBT3 ELECTRIC SLIDE-IN RANGE
Whirlpool KESC307HBT4 ELECTRIC SLIDE-IN RANGE
Whirlpool KESC307HBT5 SLIDE-IN RANGE, ELECTRIC
Whirlpool KESC307HBT6 RANGE
Whirlpool KESC307HBT8 ELECTRIC RANGE
Whirlpool KESC307HWH0 ELECTRIC SLIDE-IN RANGE
Whirlpool KESC307HWH1 ELECTRIC RANGE
Whirlpool KESC307HWH3 ELECTRIC SLIDE-IN RANGE
Whirlpool KESC307HWH4 ELECTRIC SLIDE-IN RANGE
Whirlpool KESC307HWH5 SLIDE-IN RANGE, ELECTRIC
Whirlpool KESC307HWH6 RANGE
Whirlpool KESC307HWH8 ELECTRIC RANGE
Whirlpool KESC307HWW4 ELECTRIC SLIDE-IN RANGE
Whirlpool KESC307HWW6 RANGE
Whirlpool KESC307HWW8 ELECTRIC RANGE
Whirlpool KESC308LSS0 30" Slide-In Range DESIGNER STYLE Convection Oven
Whirlpool KESH307BAL1 30" SLIDE-IN ELECTRIC RANGE
Whirlpool KESH307BAL2 30" SLIDE-IN RANGE
Whirlpool KESH307BAL3 30" ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307BAL4 30" ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307BAL5 30" SLIDE-IN RANGE
Whirlpool KESH307BAL6 30" SLIDE-IN CONVECTION RANGE
Whirlpool KESH307BAL8 30"SLIDE-IN RANGE W/CONV. OVEN
Whirlpool KESH307BAL9 30" ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307BBL1 30" SLIDE-IN ELECTRIC RANGE
Whirlpool KESH307BBL2 30" SLIDE-IN RANGE
Whirlpool KESH307BBL3 30" ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307BBL4 30" ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307BBL5 30" SLIDE-IN RANGE
Whirlpool KESH307BBL6 30" SLIDE-IN CONVECTION RANGE
Whirlpool KESH307BBL8 30"SLIDE-IN RANGE W/CONV. OVEN
Whirlpool KESH307BBL9 30" ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307BWH1 30" SLIDE-IN ELECTRIC RANGE
Whirlpool KESH307BWH2 30" SLIDE-IN RANGE
Whirlpool KESH307BWH3 30" ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307BWH4 30" ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307BWH5 30" SLIDE-IN RANGE
Whirlpool KESH307BWH6 30" SLIDE-IN CONVECTION RANGE
Whirlpool KESH307BWH8 30"SLIDE-IN RANGE W/CONV. OVEN
Whirlpool KESH307BWH9 30" ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307GAL0 30" SLIDE-IN RANGE
Whirlpool KESH307GAL1 ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307GBL0 30" SLIDE-IN RANGE
Whirlpool KESH307GBL1 ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307GBS0 ELECTRIC SLIDE - IN RANGE
Whirlpool KESH307GBS1 ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307GBT0 ELECTRIC SLIDE - IN RANGE
Whirlpool KESH307GBT1 ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307GWH0 30" SLIDE-IN RANGE
Whirlpool KESH307GWH1 ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307HBL0 ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307HBL1 ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307HBL3 ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307HBL4 ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307HBL5 SLIDE-IN RANGE, ELECTRIC
Whirlpool KESH307HBL6 ELECTRIC SLIDE IN RANGE
Whirlpool KESH307HBS0 ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307HBS1 ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307HBS3 ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307HBS4 ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307HBS5 SLIDE-IN RANGE, ELECTRIC
Whirlpool KESH307HBS6 ELECTRIC SLIDE IN RANGE
Whirlpool KESH307HWH0 ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307HWH1 ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307HWH3 ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307HWH4 ELECTRIC SLIDE-IN RANGE
Whirlpool KESH307HWH5 SLIDE-IN RANGE, ELECTRIC
Whirlpool KESH307HWH6 ELECTRIC SLIDE IN RANGE
Whirlpool KESI901PBL00 30" Slide - in Electric Oven
Whirlpool KESI901PBL00 30" SLIDE-IN ELECTRIC OVEN
Whirlpool KESI901PBL01 30" SLIDE-IN ELECTRIC OVEN
Whirlpool KESI901PBS00 30" SLIDE-IN ELECTRIC OVEN
Whirlpool KESI901PBS00 30" Slide - in Electric Oven
Whirlpool KESI901PBS01 30" SLIDE-IN ELECTRIC OVEN
Whirlpool KESI901PWH00 30" SLIDE-IN ELECTRIC OVEN
Whirlpool KESI901PWH00 30" Slide - in Electric Oven
Whirlpool KESI901PWH01 30" SLIDE-IN ELECTRIC OVEN
Whirlpool KESK901SBL00 30" Slide-In ELECTRIC OVEN
Whirlpool KESK901SBL01 30" SLIDE-IN ELECTRIC OVEN THERMAL OVEN
Whirlpool KESK901SBL02 30" SLIDE-IN ELECTRIC OVEN THERMAL OVEN
Whirlpool KESK901SBL04 30" SLIDE-IN ELECTRIC OVEN THERMAL OVEN
Whirlpool KESK901SBL05 30" SLIDE-IN ELECTRIC OVEN THERMAL OVEN
Whirlpool KESK901SBL06 30" SLIDE-IN ELECTRIC OVEN THERMAL OVEN
Whirlpool KESK901SSS00 30" Slide-In ELECTRIC OVEN
Whirlpool KESK901SSS01 30" SLIDE-IN ELECTRIC OVEN THERMAL OVEN
Whirlpool KESK901SSS02 30" SLIDE-IN ELECTRIC OVEN THERMAL OVEN
Whirlpool KESK901SSS04 30" SLIDE-IN ELECTRIC OVEN THERMAL OVEN
Whirlpool KESK901SSS05 30" SLIDE-IN ELECTRIC OVEN THERMAL OVEN
Whirlpool KESK901SSS06 30" SLIDE-IN ELECTRIC OVEN THERMAL OVEN
Whirlpool KESK901SWH00 30" Slide-In ELECTRIC OVEN
Whirlpool KESK901SWH01 30" SLIDE-IN ELECTRIC OVEN THERMAL OVEN
Whirlpool KESK901SWH02 30" SLIDE-IN ELECTRIC OVEN THERMAL OVEN
Whirlpool KESK901SWH04 30" SLIDE-IN ELECTRIC OVEN THERMAL OVEN
Whirlpool KESK901SWH05 30" SLIDE-IN ELECTRIC OVEN THERMAL OVEN
Whirlpool KESK901SWH06 30" SLIDE-IN ELECTRIC OVEN THERMAL OVEN
Whirlpool KESO140 ELECTRIC RANGES & OVENS
Whirlpool KESO140S ELECTRIC RANGES & OVENS
Whirlpool KESO145 ELECTRIC RANGES & OVENS
Whirlpool KESO145S ELECTRIC RANGES & OVENS
Whirlpool KESO170 ELECTRIC RANGES & OVENS
Whirlpool KESO170S ELECTRIC RANGES & OVENS
Whirlpool KESO175 ELECTRIC RANGES & OVENS
Whirlpool KESO175S ELECTRIC RANGES & OVENS
Whirlpool KESO176S Ranges, Electric*
Whirlpool KESS300BAL0 30" SLIDE-IN ELECTRIC RANGE
Whirlpool KESS300BWH0 30" SLIDE-IN ELECTRIC RANGE
Whirlpool KESS907SBB00 30" Built-In ELECTRIC OVEN
Whirlpool KESS907SBB01 30" SLIDE-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KESS907SBB02 30" SLIDE-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KESS907SBL00 30" Built-In ELECTRIC OVEN
Whirlpool KESS907SBL01 30" SLIDE-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KESS907SBL02 30" SLIDE-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KESS907SBL04 30" SLIDE-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KESS907SSS00 30" Built-In ELECTRIC OVEN
Whirlpool KESS907SSS01 30" SLIDE-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KESS907SSS02 30" SLIDE-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KESS907SSS04 30" SLIDE-IN ELECTRIC OVEN SELF CLEAN
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F2-E0 error wrrhodesjr Oven Repair (including Ranges and Cooktops) 2 03-19-2010 07:33 PM
frigidaire error code F10 - not listed in your error codes Skully26 Oven Repair (including Ranges and Cooktops) 2 02-16-2010 04:29 AM
error 160 Blake1111 Oven Repair (including Ranges and Cooktops) 0 10-19-2009 03:50 PM
error loc ddol98@yahoo.com Washer Repair 1 10-12-2009 12:05 PM
F H error oldbridgeguy Washer Repair 1 07-29-2009 03:58 PM
