The problem that I have on the upper oven is that it does not reach or hold the desired temp. The lower oven is fine. On the upper oven I changed the door gasket and the thermocouple and I swapped the lower heating element from the lower oven. I also cranked in a 35 F offset and still no improvement. Does this point to a bad control board AP3095479 (black). How can I test the board before I spend a load on a replacement. Thanks.
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
