Discuss
Oven Self Cleaning Problem
 in
Strange Problem with self cleaning oven. No error messages. Setting the Clean cycle starts fine (Door locks, lower element goes
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Self Cleaning Problem
  #1 (permalink)
Old 01-16-2011, 09:14 AM
Junior Member
double-g is on a distinguished road
Default Oven Self Cleaning Problem
Model Number: GLES388DS   Brand: Frigidaire   Age: 5 - 10 years
No error messages. Setting the Clean cycle starts fine (Door locks, lower element goes on) Controller allows 1 of 3 time cycles (2hr,3hr,4hr). Selecting any of these exhibits same problem.
Oven stops cleaning in about 1 hr, and never reaches proper temp. (Door unlocks, and control displays clock)
All other functions with controller work OK.
Instructons say that when the cycle is complete, Time,Door Locked, and Clean icons should remain in the display. They aren't.
Don't believe it is a temp cutout, as never reaches high temp.
Is there someting in the circuit where the time is controlled? anad what should I do?
Comments welcomed!
Ads By Google
Related Models
Frigidaire GLES388DSA Frigidaire/electric Range
Frigidaire GLES388DSB Frigidaire/electric Range
Frigidaire GLES389EBA Frigidaire/electric Range
Frigidaire GLES389EBB Frigidaire/electric Range
Frigidaire GLES389EBC Frigidaire/electric Range
Frigidaire GLES389EBD Frigidaire/electric Range
Frigidaire GLES389EBE Frigidaire/electric Range
Frigidaire GLES389EQA Frigidaire/electric Range
Frigidaire GLES389EQB Frigidaire/electric Range
Frigidaire GLES389EQC Frigidaire/electric Range
Frigidaire GLES389EQD Frigidaire/electric Range
Frigidaire GLES389EQE Frigidaire/electric Range
Frigidaire GLES389ESA Frigidaire/electric Range
Frigidaire GLES389ESB Frigidaire/electric Range
Frigidaire GLES389ESC Frigidaire/electric Range
Frigidaire GLES389ESD Frigidaire/electric Range
Frigidaire GLES389ESE Frigidaire/electric Range
Frigidaire GLES389FBA Frigidaire/electric Range
Frigidaire GLES389FBB Frigidaire/electric Range
Frigidaire GLES389FBC ELECTRIC RANGE
Frigidaire GLES389FBD ELECTRIC RANGE
Frigidaire GLES389FBE ELECTRIC RANGE
Frigidaire GLES389FBF ELECTRIC RANGE
Frigidaire GLES389FQA Frigidaire/electric Range
Frigidaire GLES389FQB Frigidaire/electric Range
Frigidaire GLES389FSA Frigidaire/electric Range
Frigidaire GLES389FSB Frigidaire/electric Range
Frigidaire GLES389FSC ELECTRIC RANGE
Frigidaire GLES389FSD ELECTRIC RANGE
Frigidaire GLES389FSE ELECTRIC RANGE
Frigidaire GLET1031CS0 Frigidaire/laundry Center
Frigidaire GLET1031FS0 Frigidaire/laundry Center
Frigidaire GLET1031FS1 LAUNDRY CENTER
Frigidaire GLET1031FS2 LAUNDRY CENTER
Frigidaire GLET1031FS4 LAUNDRY CENTER
Frigidaire GLET1041AS0 Lc - Frig Gallery
Frigidaire GLET1041AS1 Lc - Frig Gallery
Frigidaire GLET1041AS2 Frigidaire/laundrycenter
Frigidaire GLET1142CS0 Frigidaire/laundry Center
Frigidaire GLET1142FS0 Frigidaire/laundry Center
Frigidaire GLET1142FS1 LAUNDRY CENTER
Frigidaire GLET1142FS2 LAUNDRY CENTER
Frigidaire GLFC1326FW0 Frigidaire/freezer
Frigidaire GLFC1326FW1 Frigidaire/freezer
Frigidaire GLFC1326FW2 FREEZER
Frigidaire GLFC1326FW3 FREEZER
Frigidaire GLFC1526FW0 Frigidaire/freezer
Frigidaire GLFC1526FW1 Frigidaire/freezer
Frigidaire GLFC1526FW2 FREEZER
Frigidaire GLFC1526FW3 FREEZER
Frigidaire GLFC1526FW4 FREEZER
Frigidaire GLFC1526FW5 FREEZER
Frigidaire GLFC1526FW6 FREEZER
Frigidaire GLFC1526FW7 FREEZER
Frigidaire GLFC2027FW0 Frigidaire/freezer
Frigidaire GLFC2027FW1 Frigidaire/freezer
Frigidaire GLFC2027FW2 Frigidaire/freezer
Frigidaire GLFC2027FW3 Frigidaire/freezer
Frigidaire GLFC2027FW4 FREEZER
Frigidaire GLFC2027FW5 FREEZER
Frigidaire GLFC2027FW6 FREEZER
Frigidaire GLFC2528FW0 Frigidaire/freezer
Frigidaire GLFC2528FW1 Frigidaire/freezer
Frigidaire GLFC2528FW10 FREEZER
Frigidaire GLFC2528FW2 Frigidaire/freezer
Frigidaire GLFC2528FW3 Frigidaire/freezer
Frigidaire GLFC2528FW4 FREEZER
Frigidaire GLFC2528FW5 FREEZER
Frigidaire GLFC2528FW6 FREEZER
Frigidaire GLFC2528FW7 FREEZER
Frigidaire GLFC2528FW8 FREEZER
Frigidaire GLFC2528FW9 FREEZER
Frigidaire GLFH1467GW0 FREEZER
Frigidaire GLFH1467GW1 FREEZER
Frigidaire GLFH1767GW1 FREEZER
Frigidaire GLFH1779GW0 FREEZER
Frigidaire GLFH1779GW1 FREEZER
Frigidaire GLFH1779GW2 FREEZER
Frigidaire GLFH17F8HBA FREEZER
Frigidaire GLFH17F8HBB FREEZER
Frigidaire GLFH17F8HBC FREEZER
Frigidaire GLFH17F8HBD FREEZER
Frigidaire GLFH17F8HBF FREEZER
Frigidaire GLFH17F8HBG FREEZER
Frigidaire GLFH17F8HBH FREEZER
Frigidaire GLFH17F8HWA FREEZER
Frigidaire GLFH17F8HWB FREEZER
Frigidaire GLFH17F8HWC FREEZER
Frigidaire GLFH17F8HWD FREEZER
Frigidaire GLFH17F8HWE FREEZER
Frigidaire GLFH17F8HWF FREEZER
Frigidaire GLFH17F8HWG FRIGIDAIRE/FREEZER
Frigidaire GLFH17F8HWH FRIGIDAIRE/FREEZER
Frigidaire GLFH21F8HBA FREEZER
Frigidaire GLFH21F8HBB FREEZER
Frigidaire GLFH21F8HBC FREEZER
Frigidaire GLFH21F8HBD FREEZER
Frigidaire GLFH21F8HBE FREEZER
Frigidaire GLFH21F8HWA FREEZER
Frigidaire GLFH21F8HWB FREEZER
Frigidaire GLFH21F8HWC FREEZER
Frigidaire GLFH21F8HWD FREEZER
Frigidaire GLFH21F8HWE FREEZER
Frigidaire GLFH21F8HWG FREEZER
Frigidaire GLFN1326GW0 FREEZER
Frigidaire GLFN1326GW1 FREEZER
Frigidaire GLFN1326GW2 FREEZER
Frigidaire GLFN1326GW3 FREEZER
Frigidaire GLFU1467FW0 Frigidaire/freezer
Frigidaire GLFU1467FW1 FREEZER
Frigidaire GLFU1467FW2 FREEZER
Frigidaire GLFU1767FW2 Frigidaire/freezer
Frigidaire GLFU1767FW3 Frigidaire/freezer
Frigidaire GLFU1767FW4 Frigidaire/freezer
Frigidaire GLFU1767FW5 FREEZER
Frigidaire GLFU1767FW6 FREEZER
Frigidaire GLFU2067FW2 Frigidaire/freezer
Frigidaire GLFU2067FW3 Frigidaire/freezer
Frigidaire GLFU2067FW4 Frigidaire/freezer
Frigidaire GLFU2067FW5 FREEZER
  #2 (permalink)
Old 01-17-2011, 04:29 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Turn on the broiler element to be sure it works. Also while your there, check the bake element. If one of the elements don't work. It will never achieve temp. Tom ********************************************
  #3 (permalink)
Old 01-17-2011, 10:30 AM
Junior Member
ts_peach is on a distinguished road
Default
i am having a simillar problem with my Kenmore Electric Range model 790.93752 i set the clean cycle (2hr or 3hr cycle) and start it. it locks the door starts to heat and after 15 min it clicks off.
it's done this sincei first tried it after we moved in a year ago but once i was able to get it to go through the entire cycle. i don't know if this had anything to do with it, but i noticed the door handle was getting loose so i tightened it up (thought maybe it was registering the door wasn't completely locked/sealed). the clean cycle then ran correctly. but i've tightened everything up this time and still can't get it to go. oven does heat and the broil element does work.
would love to hear any other suggestion on what to troubleshoot.
  #4 (permalink)
Old 01-18-2011, 02:14 PM
Junior Member
Default
Quote:
Both elements work. Book says only bake element used in cleaning. Don't remember if both elements were on when it worked.
Tried using bake @ 550F with bake element. but no results after 3 hrs.
  #5 (permalink)
Old 01-19-2011, 05:00 AM
Senior Expert
APP Volunteer
Default
So what you saying is the bake element is not working. You need to pull the element and check it. Oh, by the way, both elements are supposed to come on in a clean cycle. Tom ********************************************
  #6 (permalink)
Old 01-19-2011, 07:32 AM
Junior Member
Default
What I am trying to say is:
Lower element works OK when baking,
Upper element works OK when broiling.
Only the lower element comes on during cleaning cycle. That's why it doesn't come up to temp.
Also, after running a short clean cycle, unit shuts off and door unlocks. There is no "cool down" time
Does this indicate a bad controller? (All functions work except the clean cycle)
Looking at service data sheet: states "during the cleaning process, the oven uses the bake element"
I tried baking at 550F (highest temp) and it got there, but not hot enough to degrease.
Is the thermostat bypassed for the cleaning process?
  #7 (permalink)
Old 01-19-2011, 07:36 AM
Senior Expert
APP Volunteer
Default
Yes!! Tom
  #8 (permalink)
Old 01-19-2011, 04:22 PM
Junior Member
Default
OK...I'll look around for a controller
Thanks.../S
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool oven cleaning problem jwwilliams2 Oven Repair (including Ranges and Cooktops) 0 03-18-2010 01:46 PM
self cleaning oven only works on self cleaning moblo1@sbcglobal.net Oven Repair (including Ranges and Cooktops) 0 03-03-2010 05:18 AM
self-cleaning oven got so hot when cleaning that it melted the surrounding cabinet do anne Oven Repair (including Ranges and Cooktops) 3 12-11-2009 09:03 PM
Cleaning problem craig h Oven Repair (including Ranges and Cooktops) 1 10-20-2009 04:59 PM
frigidaire self cleaning oven problem kathleenjones03@yahoo.com Oven Repair (including Ranges and Cooktops) 1 03-14-2009 08:42 PM
