| » Jenn Air double Oven Error code "Fr" |
Model Number: WW30430B Brand: Jenn-Air Age: More than 10 years
I have a double oven Jenn Air where the top oven works fine, but the bottom oven generates a code "Fr" whenever you try to use it (hit bake, enter temp, it seems to want to start working then stops and beeps with code Fr (at least it looks like a lower case R).
I ordered and replaced the temperature sensor which did not help. A useful sign that both the old and new sensors were working correctly is that when the sensor was disconnected, the cabinet fan (not convection fan) on the oven turned on (like the oven was hot). Anyway, it looks like I still have a problem which is now pointing me towards the relay board. Unfortunately, there are two relay boards listed in the parts so I don't know which one to order (I'm leaning towards the "lower" board since that's the oven having problems). So my questions are: a) is replacing the relay board the right thing to do at this time and b) which relay board should I replace? Thanks in advance for any help you can provide. Ads By Google Related Models |
Quote:
Conor, You had it all along, Yes the code "Fr" was in regards to the lower oven sensor or relay board The lower oven board was not communicating properly to the upper(main)oven control/relay board. Yes, order and replace the Lower Oven Relay board, leave the new sensor installed(just in case), double check the wiring for loose connections and possible damage, and you'll be alright. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| dishwasher shows error code "88" Kitchenaid KUDS01DJ etc. | mariopapas | Dishwasher Repair | 0 | 12-04-2010 04:49 AM |
| MAYTAG NEPTUNE error code: "E5 or L5" ? | skalesplitur | Dryer Repair | 1 | 03-07-2010 09:08 AM |
| Dacor EORS130 error code "CO1" displayed | sjoyce15 | Oven Repair (including Ranges and Cooktops) | 0 | 01-05-2010 09:32 AM |
| Jenn Air F5 error code - "Clock" or Power relay board? | chanpaul | Oven Repair (including Ranges and Cooktops) | 2 | 12-08-2009 12:22 PM |
| Whirlpool Double Oven "E6 F2" Error | nessiedsj | Oven Repair (including Ranges and Cooktops) | 1 | 11-21-2009 01:43 PM |
