Discuss
Burner on a Flat top
 in
All burners (GE Select) when turned on (together or not) goes on and off unless its in the very high
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Burner on a Flat top
  #1 (permalink)
Old 10-11-2007, 05:11 PM
mckrsix mckrsix is offline
Junior Member
mckrsix is on a distinguished road
Default Burner on a Flat top
Brand: GE   Age: 1 - 5 years
All burners (GE Select) when turned on (together or not) goes on and off unless its in the very high setting?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-12-2007, 03:27 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Seems normal to me, do the burners heat up well at a medium control setting?
__________________
  #3 (permalink)
Old 10-12-2007, 06:28 PM
Junior Member
Default
Well my wife tried to cook noodles on high and it comes almost a boil and then you see it turn off. Then a little bit later it turns back on. They all do this the oven is fine though. Its plugged in to a 15Amp circuit. Its just odd.So they share a common junction of some sort. (thermostat,power surge/draw thru circuit or ?) As far as the Medium setting I tryed it turns on for about 6 to 8 seconds and kicks off. No pan on it.
  #4 (permalink)
Old 10-12-2007, 07:36 PM
Senior Expert
APP Volunteer
Default
You have a bad burner control, just click on model # to order.
__________________
  #5 (permalink)
Old 10-14-2007, 11:29 AM
Junior Member
Default
All 4 have a bad control? They all do it. They all have there own controller right?
  #6 (permalink)
Old 10-14-2007, 05:58 PM
Senior Expert
APP Volunteer
Default
Turn on all the burner controls to high. Now, do they all go off at the same time??
__________________
  #7 (permalink)
Old 10-14-2007, 08:32 PM
Junior Member
Default
So I turned them on high they all seemed to stay on > So then I put a pan of water on them. Moved the pan to each burner (on high still) Thats when the burner starts to turn on and off when the pan is on them? It takes less than a min for the burners to do this. The water by the way did not boil. I must be missing something or what!? heck it could be normal but the water still didn't boil. By the way when they are not on high and all on a setting of eight they seemed to turn off some what close to each other but no not at the same time.
  #8 (permalink)
Old 10-14-2007, 10:20 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi mckrsix
In order to provide you with accurate advise I need the complete model number of your range.
__________________
Professional appliance repair in Los Angeles, California.
  #9 (permalink)
Old 10-15-2007, 04:30 AM
Senior Expert
APP Volunteer
Default
Need make and model # for this.
Each burner has a over temperature thermostat. Usually takes a few minutes to click back on. If this is true, you have problems with each burner.
Check your line voltage, might be higher than 240 volts, if so that would be your problem
__________________
  #10 (permalink)
Old 10-15-2007, 04:17 PM
Junior Member
Default
Hi, Pain in the but here again. The model number is JBP61WB1WW GE Select. 240v I haven't thought of that I will check I would be surprised though.
Thank you!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to add a simmer burner? rcmizen Oven Repair (including Ranges and Cooktops) 1 04-05-2008 06:51 PM
Burner won't ignite flaumbetty Oven Repair (including Ranges and Cooktops) 5 01-25-2008 06:39 AM
One burner will not spark bulldog217 Oven Repair (including Ranges and Cooktops) 1 09-29-2007 12:06 PM
electricrange burner jameswadw Oven Repair (including Ranges and Cooktops) 3 09-15-2007 10:53 PM
No clicking from one burner Joepilot Oven Repair (including Ranges and Cooktops) 4 08-30-2007 06:36 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
