Discuss
Tappan electric range, unable to heat oven
 in
[FONT='Verdana','sans-serif']We have a Tappan electric range with a self-cleaning oven, Model No. 31-5592-23/01. On the panel, the word, locked, lights
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Tappan electric range, unable to heat oven
  #1 (permalink)
Old 01-14-2011, 11:19 AM
Junior Member
c.clowe is on a distinguished road
Default Tappan electric range, unable to heat oven
Brand: Tappan   Age: More than 10 years
[FONT='Verdana','sans-serif']We have a Tappan electric range with a self-cleaning oven, Model No. 31-5592-23/01. On the panel, the word, locked, lights up and appears for a second and reappears periodically. We also hear a timer or fan running. This stops when the oven door is open. We are unable to set the oven to clean, broil or bake; the temperature control settings do not hold. We pressed cancel but it does not cancel the locked oven door problem nor does unplugging the range and waiting a half hour. The stove burners are manual and work fine. We have an Owner’s Guide but not a manual. What part do we need to purchase to fix it? What self help instructions are available? [/font]
ccgoldylocks-appliancepartspro@yahoo.com
forum@appliancepartspros.com
  #2 (permalink)
Old 01-14-2011, 03:21 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
You should start by,
Remove the back panel from the range, or remove the cooktop and burner box base,
Check the wiring , switches, and actuator rod on the self clean door lock motor,located between the burner box base and oven insulation on the back end of the range.
If the switches, wires, or actuator rod is damaged,etc, it will mis inform the control and make it think the door is locked for the self clean cycle,
That's were I'd start,
I've attached some part numbers and diagrams for a visual reference, and some of the possible parts needed
Part number: AP3873473
Part number: AP2124526
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana electric range (oven) wont heat up flukekiller Oven Repair (including Ranges and Cooktops) 6 12-23-2011 06:01 AM
Tappan electric range Gladys Riggs Oven Repair (including Ranges and Cooktops) 0 07-23-2010 09:33 PM
Tappan Range oven door JennieB Oven Repair (including Ranges and Cooktops) 4 05-13-2009 02:06 PM
Tappan Electric Range sherylwright Oven Repair (including Ranges and Cooktops) 0 03-09-2009 11:03 PM
