Discuss
Humming Kenmore
 in
I have a newly installed Kenmore range. The burners and/or oven hum when at mdium to high temperatures. At low
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Humming Kenmore
  #1 (permalink)
Old 12-01-2008, 06:29 PM
Junior Member
rsnowman13 is on a distinguished road
Default Humming Kenmore
Model Number: 790.71329702   Brand: Kenmore   Age: Less than 1 year
I have a newly installed Kenmore range. The burners and/or oven hum when at mdium to high temperatures. At low temps, no noise is heard. What can cause this?
Ads By Google
Related Models
Kenmore 790.74403990  DUAL FUEL RANGE
Kenmore 790.74403991  DUAL FUEL RANGE
Kenmore 790.74403992  DUAL FUEL RANGE
Kenmore 790.74403993  DUAL FUEL RANGE
Kenmore 790.74403994  DUAL FUEL RANGE
Kenmore 790.74403995  DUAL FUEL RANGE
Kenmore 790.74503990  DUAL FUEL RANGE
Kenmore 790.74503991  DUAL FUEL RANGE
Kenmore 790.75503200  RANGE
Kenmore 790.75503201  RANGE
Kenmore 790.79012100  GAS RANGE
Kenmore 790.79013100  GAS RANGE
Kenmore 790.79014100  GAS RANGE
Kenmore 790.79019100  GAS RANGE
Kenmore 790.79112200  SEARS/GAS RANGE
Kenmore 790.79112201  SEARS/GAS RANGE
Kenmore 790.79112202  SEARS/GAS RANGE
Kenmore 790.79113200  SEARS/GAS RANGE
Kenmore 790.79113201  SEARS/GAS RANGE
Kenmore 790.79113202  SEARS/GAS RANGE
Kenmore 790.79114200  SEARS/GAS RANGE
Kenmore 790.79114201  SEARS/GAS RANGE
Kenmore 790.79114202  SEARS/GAS RANGE
Kenmore 790.79119200  SEARS/GAS RANGE
Kenmore 790.79119201  SEARS/GAS RANGE
Kenmore 790.79119202  SEARS/GAS RANGE
Sears 790.8  OUTDOORS POST & WALL LAMP
Kenmore 790.8  HAIR CLIPPERS
Kenmore 790.90102200  ELECTRIC RANGE
Kenmore 790.90104200  ELECTRIC RANGE
Kenmore 790.91010200  ELECTRIC RANGE
Kenmore 790.91011200  ELECTRIC RANGE
Kenmore 790.91012300  ELECTRIC RANGE
Kenmore 790.91014300  ELECTRIC RANGE
Kenmore 790.91022102  RANGE
Kenmore 790.91102000  ELECTRIC RANGE
Kenmore 790.91102001  ELECTRIC RANGE
Kenmore 790.91105890  ELECTRIC RANGE
Kenmore 790.91105891  ELECTRIC RANGE
Kenmore 790.91105892  ELECTRIC RANGE
Kenmore 790.91106890  ELECTRIC RANGE
Kenmore 790.91106891  ELECTRIC RANGE
Kenmore 790.91106892  RANGE
Kenmore 790.91107000  ELECTRIC RANGE
Kenmore 790.91107001  ELECTRIC RANGE
Kenmore 790.9115892  ELECTRIC RANGE
Kenmore 790.9116892  ELECTRIC RANGE
Kenmore 790.92310100  ELECTRIC RANGE
Kenmore 790.92311100  ELECTRIC RANGE
Kenmore 790.92312100  ELECTRIC RANGE
Kenmore 790.92312300  ELECTRIC RANGE
Kenmore 790.92313300  ELECTRIC RANGE
Kenmore 790.92314100  ELECTRIC RANGE
Kenmore 790.92314300  ELECTRIC RANGE
Kenmore 790.92315100  ELECTRIC RANGE
Kenmore 790.92410100  ELECTRIC RANGE
Kenmore 790.92410102  ELECTRIC RANGE
Kenmore 790.92410103  ELECTRIC RANGE
Kenmore 790.92410104  ELECTRIC RANGE
Kenmore 790.92411100  ELECTRIC RANGE
Kenmore 790.92411102  ELECTRIC RANGE
Kenmore 790.92411103  ELECTRIC RANGE
Kenmore 790.92411104  ELECTRIC RANGE
Kenmore 790.92412100  ELECTRIC RANGE
Kenmore 790.92412102  ELECTRIC RANGE
Kenmore 790.92412103  ELECTRIC RANGE
Kenmore 790.92412104  ELECTRIC RANGE
Kenmore 790.92413200  ELECTRIC RANGE
Kenmore 790.97471790  ELECTRIC RANGE
Kenmore 790.97475790  ELECTRIC RANGE
Kenmore 790.97476790  ELECTRIC RANGE
Kenmore 790.97478790  ELECTRIC RANGE
Kenmore 791.0  HAIR CLIPPERS
Kenmore 791.4  HAIR CLIPPERS
Kenmore 791.6102190  GAS RANGE
Kenmore 791.6102890  GAS RANGE
Kenmore 791.6112190  GAS RANGE
Kenmore 791.6112890  GAS RANGE
Kenmore 791.6162190  GAS RANGE
Kenmore 791.6162890  GAS RANGE
Kenmore 791.6262190  ELECTRIC RANGE
Kenmore 791.6262890  ELECTRIC RANGE
Kenmore 791.6272190  ELECTRIC RANGE
Kenmore 791.6272890  ELECTRIC RANGE
Kenmore 791.6302190  GAS RANGE
Kenmore 791.6302890  GAS RANGE
Kenmore 791.6412190  ELECTRIC RANGE
Kenmore 791.6412890  ELECTRIC RANGE
Kenmore 791.734891  GAS RANGE
Kenmore 791.734898  GAS RANGE
Kenmore 791.783889  GAS RANGE
Kenmore 791.7838890  KENMORE GAS RANGE
Kenmore 791.7838891  GAS RANGE
Kenmore 791.7839090  GAS RANGE
Kenmore 791.7839091  GAS RANGE
Kenmore 791.7839092  GAS RANGE
Kenmore 791.7839094  GAS RANGE
Kenmore 791.785889  GAS RANGE
Kenmore 791.7858890  KENMORE GAS RANGE
Kenmore 791.7858892  GAS RANGE
Kenmore 791.7859090  GAS RANGE
Kenmore 791.7859091  GAS RANGE
Kenmore 791.7859092  GAS RANGE
Kenmore 791.7859093  GAS RANGE
Kenmore 791.7859094  GAS RANGE
Kenmore 791.7859095  GAS RANGE
Kenmore 791.7898810  KENMORE GAS RANGE
Kenmore 791.7898814  GAS RANGE
Kenmore 791.7898815  GAS RANGE
Kenmore 791.7898884  GAS RANGE
Kenmore 791.7898885  GAS RANGE
Kenmore 791.7898894  GAS RANGE
Kenmore 791.7898895  GAS RANGE
Kenmore 791.7899010  GAS RANGE
Kenmore 791.7899011  GAS RANGE
Kenmore 791.7899012  GAS RANGE
Kenmore 791.7899080  GAS RANGE
Kenmore 791.7899081  GAS RANGE
Kenmore 791.7899082  GAS RANGE
Kenmore 791.7899090  GAS RANGE
  #2 (permalink)
Old 12-02-2008, 03:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Some noise coming from the oven metal parts while they are heating up is normal. I believe you can find some information regarding this issue in the Owner manual.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-02-2008, 04:08 PM
Junior Member
Default
I've tried all of the adjustments listed in the owner's manual. Adjusting the burners raised the point where the hum is heard, but it is still present. Also tried changing to a larger supply line, as suggested by a friend that is a plumber. Again, the noise is still present.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Model 110 Washer humming/popping circuit shenanigan Washer Repair 4 12-14-2009 12:54 PM
Kenmore 17039 making loud humming sound RobWestergaard Dishwasher Repair 0 11-28-2009 10:27 AM
KenMore Dishwasher-Humming-not washing rickneedshelp Dishwasher Repair 0 03-27-2009 05:02 PM
kenmore 790 humming noise dromonk Oven Repair (including Ranges and Cooktops) 5 12-20-2008 12:07 AM
Kenmore makes loud humming when started, cycle does not begin mrbill74 Dishwasher Repair 1 10-21-2008 03:56 PM
