| » No display on oven/range control board |
Model Number: FGFB75DSE Brand: Frigidaire Age: 1 - 5 years
I purchased a Frigidaire free standing gas range from Best Buy in May 2006. Everything worked fine until this past Thanksgiving. The display on the control board (clock/timer) was blank, and none of the buttons were working. I checked to see if there was power coming from the wall outlet. It was working properly. I checked if there was power going through the range. The electric igniters were functioning properly. The only possible explanations are that (1) the control board is not getting power due to faulty wire(s) and/or (2) the control board is dead. Is there a way I can check if the control board still works without purchasing a new one? Is there a way to test if power is coming to the connector? Are there any other explanations that may cause the control board to not function? Unfortunately, since most of the functions on the range are connected to the control board, the only thing I can use is the top burners. Any advice/help would be greatly appreciated. Thanks! Jean Related Models |
Hi i have a same problem Please let me know what did you do. I can get parts on line at "********" part#PT11289582
it's a bout $130 they call it is a clock, but my oven is older then yours. Thank you! Laszlo bozsi1@ameritech.net Last edited by laszlo : 12-01-2008 at 06:37 PM. Reason: can not add link to post |
| Display Modes | |
| oven control board | donaldora | Oven Repair (including Ranges and Cooktops) | 1 | 11-29-2008 04:57 PM |
| replacing kenmore range control board | fotodik | Oven Repair (including Ranges and Cooktops) | 3 | 08-26-2008 08:30 AM |
| Thermador oven Display circuit board | Willerm | Oven Repair (including Ranges and Cooktops) | 0 | 07-25-2008 05:20 PM |
| GE oven control board | larry ryan | Oven Repair (including Ranges and Cooktops) | 1 | 07-19-2008 10:14 AM |
| control board display on | phillip melton | Oven Repair (including Ranges and Cooktops) | 3 | 02-18-2008 05:25 PM |
