Discuss
Temperature sensor/closed relays on control
 in
I am getting a F3 fault code with an E2 Error code on the temp sensor. I checked the ohms
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Temperature sensor/closed relays on control
  #1 (permalink)
Old 12-01-2008, 03:39 PM
g323 g323 is offline
Junior Member
g323 is on a distinguished road
Default Temperature sensor/closed relays on control
Model Number: RS610PXGW1   Brand: Whirlpool   Age: 5 - 10 years
I am getting a F3 fault code with an E2 Error code on the temp sensor. I checked the ohms and got the 1080 that the tech sheet said that I should get if the sensor is ok. The tech sheet said to check the control for welded closed relays. If that is the problem will I need a new control or can the control I have be fixed?
Related Models
Whirlpool RS610PXGW1
Whirlpool RS610PXGW10 30" Drop - in Electric Standard Clean Oven
Whirlpool RS610PXGW11 30" Drop - in Electric Standard Clean Oven
Whirlpool RS610PXGW2
Whirlpool RS610PXGW3
Whirlpool RS610PXGW7
Whirlpool RS610PXGW8
Whirlpool RS610PXGW9
Whirlpool RS610PXK0
Whirlpool RS610PXK1
Whirlpool RS610PXK2
Whirlpool RS610PXK3
Whirlpool RS610PXV0
Whirlpool RS610PXV1
Whirlpool RS610PXV2
Whirlpool RS610PXYH0
Whirlpool RS610PXYH1
Whirlpool RS610PXYH2
Whirlpool RS610PXYH3
Whirlpool RS610PXYH4
General Electric RS622GN1 Electric range
General Electric RS622GP1 Electric range
General Electric RS622GP2BG Electric range
General Electric RS622GP3BG Electric range
Whirlpool RS6300XKW0
Whirlpool RS6300XKW1
Whirlpool RS6300XKW2
Whirlpool RS6300XKW3
Whirlpool RS6300XVN0
Whirlpool RS6300XVN1
Whirlpool RS6300XVN2
Whirlpool RS6300XVW0
Whirlpool RS6300XVW1
Whirlpool RS6300XVW2
Whirlpool RS6305XYN2
Whirlpool RS6305XYN3
Whirlpool RS6305XYN4
Whirlpool RS6305XYN5
Whirlpool RS6305XYN6
Whirlpool RS6305XYW0
Whirlpool RS6305XYW1
Whirlpool RS6305XYW2
Whirlpool RS6305XYW3
Whirlpool RS6305XYW4
Whirlpool RS6305XYW5
Whirlpool RS6305XYW6
Whirlpool RS630PXBH0
Whirlpool RS630PXBH1
Whirlpool RS630PXK0
Whirlpool RS630PXK1
Whirlpool RS630PXK2
Whirlpool RS630PXK3
Whirlpool RS630PXV0
Whirlpool RS630PXV1
Whirlpool RS630PXV2
Whirlpool RS630PXYH0
Whirlpool RS630PXYH1
Whirlpool RS630PXYH2
Whirlpool RS630PXYH3
Whirlpool RS630PXYH4
General Electric RS647G*05 Electric range
General Electric RS647G*H1 Electric range
General Electric RS647G*J1 Electric range
General Electric RS647G*J2 Electric range
General Electric RS647G*J3 Electric range
General Electric RS647G*J4 Electric range
General Electric RS647G*J5 Electric range
General Electric RS647G*J6 Electric range
General Electric RS647G*J8 Electric range
Whirlpool RS660BXBH0
Whirlpool RS660BXBH1
Whirlpool RS660BXBH2
Whirlpool RS660BXK0
Whirlpool RS660BXK1
Whirlpool RS660BXK2
Whirlpool RS660BXK3
Whirlpool RS660BXK4
Whirlpool RS660BXV0
Whirlpool RS660BXV1
Whirlpool RS660BXV2
Whirlpool RS660BXYH0
Whirlpool RS660BXYH1
Whirlpool RS660BXYH2
Whirlpool RS660BXYH3
Whirlpool RS6700XKW0
Whirlpool RS6700XKW1
Whirlpool RS6700XKW2
Whirlpool RS6700XKW3
Whirlpool RS6700XKW4
Whirlpool RS6700XVN0
Whirlpool RS6700XVW0
Whirlpool RS670PXK0
Whirlpool RS670PXK1
Whirlpool RS670PXK2
Whirlpool RS670PXK3
Whirlpool RS670PXK4
Whirlpool RS670PXV0
Whirlpool RS6750XV1
Whirlpool RS6750XVN0
Whirlpool RS6750XVN1
Whirlpool RS6750XVN2
Whirlpool RS6750XVW0
Whirlpool RS6750XVW1
Whirlpool RS6750XVW2
Whirlpool RS6755XYN0
Whirlpool RS6755XYN1
Whirlpool RS6755XYN2
Whirlpool RS6755XYN5
Whirlpool RS6755XYN6
Whirlpool RS6755XYN7
Whirlpool RS6755XYW0
Whirlpool RS6755XYW1
Whirlpool RS6755XYW2
Whirlpool RS6755XYW5
Whirlpool RS6755XYW6
Whirlpool RS6755XYW7
Whirlpool RS675PXBH0
Whirlpool RS675PXBH1
Whirlpool RS675PXBH2
Whirlpool RS675PXBQ0
  #2 (permalink)
Old 12-01-2008, 04:27 PM
Drags1998 Drags1998 is offline
Senior Expert
APP Volunteer
Drags1998 is on a distinguished road
Default
You will need a New Control if the contacts are welded!!
__________________
  #3 (permalink)
Old 12-01-2008, 06:20 PM
Junior Member
Default
Is that an easy repair to make or should I get a pro to do it? If someone else fixes it is it usually a costly repair?
  #4 (permalink)
Old 12-01-2008, 06:37 PM
Senior Expert
APP Volunteer
Default
YES with a warantee!!!!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Temperature sensor problem stevetra Washer Repair 3 03-03-2009 02:57 PM
Thermador Temperature sensor replacement jameysant Oven Repair (including Ranges and Cooktops) 3 11-27-2008 08:32 PM
Temperature Sensor Error santaray Dishwasher Repair 1 04-06-2008 09:23 PM
changing control panel and sensor joeromano1021 Oven Repair (including Ranges and Cooktops) 1 01-30-2008 08:15 AM
RE: Clock Assembly or Temperature Sensor Joyce Oven Repair (including Ranges and Cooktops) 0 10-20-2007 02:12 PM
