| » Jenn-air double oven |
Model Number: JJW9630AAB Brand: Jenn-Air Age: 5 - 10 years
My clock had shifted down so i took control panel off to screw/glue it back. I left the power on because i had done it in the past. after 36 hours, i connected the control panel up but saw no indication on it. cycled breaker no change. left breaker off for a min then on nothing. checked voltage to relay board and it said 160. Curious why 160. either 120 or 240V should be there. before and immediately after control power was removed, i noticed oven lights on. now i have no oven light either on the bottom or top. found the schematic on top of oven. looked at it and saw that 10 v is supplied to control panel. no voltage on the J1. i gather i have a relay board failure then? what could have caused it? oven lights are fed from relay board as well.
Well appliance man came and checked what i had done. my meter was off and he concluded that the relay board needs changing. Anyone knows what the part number is to the relay board? model JJW9630AAB. This is the relay board feeding power to the control board.
| Display Modes | |
| Jenn-Air double wall oven | Leo310 | Oven Repair (including Ranges and Cooktops) | 1 | 01-14-2011 07:25 AM |
| Jenn Air Double Oven | barrymick | Oven Repair (including Ranges and Cooktops) | 0 | 08-16-2010 06:54 PM |
| Jenn Air Double Wall Oven | slcapehart@windstream.net | Oven Repair (including Ranges and Cooktops) | 5 | 01-14-2010 08:11 PM |
| F1/F7 problem with Jenn Air double oven | Fish Head | Oven Repair (including Ranges and Cooktops) | 1 | 09-29-2009 10:12 AM |
| Jenn-Air double wall oven | Donenrico | Oven Repair (including Ranges and Cooktops) | 1 | 09-03-2009 05:46 PM |
