Discuss
Viking ignitor troubleshooting
 in
I read through various posts describing sparking issues with Viking ranges (they seem pretty common) but could not determine what
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Viking ignitor troubleshooting
  #1 (permalink)
Old 11-30-2008, 06:36 PM
Junior Member
wordfool is on a distinguished road
Default Viking ignitor troubleshooting
Model Number: VDSC307-4B   Brand: -other-   Age: 1 - 5 years
I read through various posts describing sparking issues with Viking ranges (they seem pretty common) but could not determine what might be my problem.
- All four ignitors spark continuously when even just one burner is lit.
- The spark from each ignitor seems to be grounding to the burner ring, not the flame.
- disconnecting one, two, or three ignitor cables does not solve the issue... the remaining connected ignitor keep sparking, regardless of which ring is on.
- disconnecting all four ignitor cables will cause one or all to try to ground to the nearest piece of oven steel when any burner is on. In other words, there is apparently no problem with the charge getting to the sparkers themselves but there's apparently some problem with the system acknowledging a ground.
Sounds to me like there's some issue with the control module, otherwise I would have been able to isolate the bad sparker. Does that sound right? I took the front panel off and all burner valves are clean and all wires seem in good condition. I also could see no evidence of cracking of any of the ceramic posts.
Any idea appreciated.
Ads By Google
Related Models
Gaggenau VE112-612
Frigidaire VE21AW5 Tap(v1) / Electric Range
Amana VE3013 WASHER-TOP LOADING
Frigidaire VE30AW5 Tap(v1) / Electric Range
Frigidaire VE30BW4 Tap(v1) / Electric Range
Frigidaire VE30CW4 Tap(v1) / Electric Range
Gaggenau VE313-613
Amana VE5013 WASHER-TOP LOADING
Amana VEND-10.000 COMMERCIAL MICROWAVES
Amana VEND-10.A COMMERCIAL MICROWAVES
Amana VEND-10.B COMMERCIAL MICROWAVES
Amana VEND-10.C COMMERCIAL MICROWAVES
Amana VEND-10.F COMMERCIAL MICROWAVES
Amana VEND-10.G COMMERCIAL MICROWAVES
Amana VEND-10.H COMMERCIAL MICROWAVES
Amana VEND-10.J COMMERCIAL MICROWAVES
Amana VEND-7.003 COMMERCIAL MICROWAVES
Amana VEND-7.004 COMMERCIAL MICROWAVES
Amana VEND-7.005 COMMERCIAL MICROWAVES
Amana VEND-7.A COMMERCIAL MICROWAVES
Amana VEND-7.B COMMERCIAL MICROWAVES
Amana VEND-7D.001 COMMERCIAL MICROWAVES
Amana VEND-7D.A COMMERCIAL MICROWAVES
Amana VEND10 COMMERCIAL MICROWAVES
Amana VEND11 COMMERCIAL MICROWAVES
Amana VEND11B COMMERCIAL MICROWAVES
Hoover VER1360AGH RANGE- F/S STD ELE
Gaggenau VF112-610
Gaggenau VF230-610
Gaggenau VF332-610
Frigidaire VG21AW3 Tap(v1) / Gas Range
Frigidaire VG21AW3-23 Tap(v2) / Gas Range
Gaggenau VG223-812
Gaggenau VG230-811
Gaggenau VG231-211CA
Gaggenau VG232-212CA
Amana VG3019 WASHER-TOP LOADING
Frigidaire VG30AW3 Tap(v1) / Gas Range
Frigidaire VG30AW3-23 Tap(v2) / Gas Range
Frigidaire VG30BW2 Tap(v1) / Gas Range
Frigidaire VG30BW2-23 Tap(v2) / Gas Range
Frigidaire VG30CW2 Tap(v1) / Gas Range
Frigidaire VG30CW2-23 Tap(v2) / Gas Range
Gaggenau VG330-811
Gaggenau VG352-812
Gaggenau VG353-112
Gaggenau VG353-212
Frigidaire VG36DW2 Tap(v1) / Gas Range
Frigidaire VG36DW2-23 Tap(v2) / Gas Range
Amana VG5019 WASHER-TOP LOADING
Amana VHC-2 RANGE- S/C S/I DDRAFT GAS
General Electric VISR208DT8WW Washer
General Electric VISR208DTAWW Washer
General Electric VISR309JT5AA Washer
General Electric VISR309JT6AA Washer
General Electric VISR309JT8AA Washer
General Electric VISR309JTAAA Washer
General Electric VJSR2070T2AB Washer
General Electric VJSR2070T2WB Washer
General Electric VJSR2070T3AB Washer
General Electric VJSR2070T3WB Washer
General Electric VJSR2070T5AB Washer
General Electric VJSR2070T5WB Washer
General Electric VJSR2070T6AB Washer
General Electric VJSR2070T6WB Washer
General Electric VJSR2070T8AB Washer
General Electric VJSR2070T8WB Washer
General Electric VJSR2070TAAB Washer
General Electric VJSR2070TAWB Washer
Gaggenau VK111-610
Gaggenau VK230-610
General Electric VKSR2100T2WW Washer
General Electric VKSR2100T3WW Washer
General Electric VKSR2100T5WW Washer
General Electric VKSR2100T6WW Washer
General Electric VKSR2100T8WW Washer
General Electric VKSR2100TAWW Washer
General Electric VKXR4100T2WW Washer
General Electric VKXR4100T3WW Washer
General Electric VKXR4100T5WW Washer
General Electric VKXR4100T6WW Washer
General Electric VKXR4100T8WW Washer
General Electric VKXR4100TAWW Washer
Gaggenau VL021-707
Gaggenau VL022-707
Gaggenau VL023-707
Gaggenau VL030-707
Gaggenau VL031-707
Gaggenau VL040-707
Gaggenau VL041-707
Gaggenau VL051-707
Gaggenau VL330-707
Gaggenau VL331-707 211100 UP
Gaggenau VL331-707upto 211099
General Electric VLD4209L15BB Dishwasher
General Electric VLD4209L15SS Dishwasher
General Electric VLD4209L15WW Dishwasher
General Electric VLD4209L20BB DISHWASHER
General Electric VLD4209L20SS DISHWASHER
General Electric VLD4209L20WW DISHWASHER
General Electric VLLR1020T0WO Washer
General Electric VLLR1020T1WO Washer
General Electric VLSR1090G0WW Washer
General Electric VLSR1090G2WW Washer
General Electric VLXR1020A0WO Washer
General Electric VLXR1020A1WO Washer
General Electric VLXR1020A2WO Washer
General Electric VLXR1020A3WO Washer
General Electric VLXR1020A4WO Washer
General Electric VLXR1020A4WW Washer
General Electric VLXR1020A5WO Washer
General Electric VLXR1020D0WO Washer
General Electric VLXR1020D2WO Washer
General Electric VLXR1020D5WO Washer
General Electric VLXR1020T2WB Washer
General Electric VLXR1020T3WB Washer
General Electric VLXR1020T4WB Washer
General Electric VLXR1020T5WB Washer
General Electric VLXR1020T8WB Washer
  #2 (permalink)
Old 12-01-2008, 09:29 AM
Junior Member
Default
I shuld also note that I just had the range installed in a new location so I also plan to check the ground and polarity of the outlet. However, the disconnected ignition wires sparking to the range frame suggests the frame is properly grounded.
  #3 (permalink)
Old 12-01-2008, 03:21 PM
Junior Member
Default
OK, this Viking ignitor issue had a happy ending... reverse polarity! Re-wired and the problem is now gone.
However, I do have a problem with one of the burners in that on High there is only intermittent flame from about a quarter of the burner ring. All the holes on the ring seem clear and fine... any ideas what might cause this issue?
  #4 (permalink)
Old 12-21-2010, 09:28 PM
Junior Member
bruced is on a distinguished road
Smile Solution to constant sparking
I hit the same problem after a new ignitor was installed. The burners would light but the ignitors would keep sparking. The one clue was that if all the burners were lit then the sparking would stop.
The problem was that the burners were miswired to the ignitor. The electrical connections from the ignitor to the control knobs are labeled 1 to 4. The electrical connections from the ignitor to the burners are labeled 1 to 4. If these don't match then things don't work. That is, if the knob that controls the front-left burner is attached to terminal one, then the front-left burner had better be attached to terminal one.
The reason is simple. When you turn on the gas the ignitor sends sparks to all four burners, for safety reasons. But it also monitors to see if the *specified* burner is lit. Once it detects heat, it stops sparking. If it's monitoring the wrong burner then it won't detect heat. It was an easy fix once we figured this out.
After this we still had one burner that when lit wouldn't stop the sparking. That's because its wire was loose, so that's another possible cause. It's odd that it's wire had a good enough connection to drive the spark, but not a good enough connection to detect ignition.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Viking Range dreaded ignitor ISLAND Oven Repair (including Ranges and Cooktops) 1 12-21-2010 09:29 PM
Viking cooktop ignitor Doug Camphuis Oven Repair (including Ranges and Cooktops) 0 11-28-2009 04:10 PM
Viking range ignitor won't stop dixitquedeus Oven Repair (including Ranges and Cooktops) 0 10-08-2009 08:10 PM
Substitute Oven Ignitor for Viking radialengine Oven Repair (including Ranges and Cooktops) 2 08-17-2009 05:13 PM
Viking broiler ignitor problem skidgllfs Oven Repair (including Ranges and Cooktops) 4 03-27-2009 04:07 AM
