| » Oven takes forever to heat up |
Model Number: KEDC205YWH Brand: Kitchen Aid Age: More than 10 years
I have a Kitchen Aid stove/range, Model No. KEDC205YWH. It takes forever for my oven heating elements (both bottom and broiler) to heat up to temperature. I can set the thermostat for the oven to 350 degrees and it takes 20-30 minutes to reach desired temperature. But it eventually does, just takes to long. Everything else seems to work otherwise. Stove top, clock, thermostat, timer, etc. all work fine. What could be the problem?
Are the element(s) bright red? You could have a voltage problem to the oven causing the long pre-heat time....might check to see what the voltage is to the unit to be sure it is 240 volts....however ranges, especailly electric ones, do take at least 20 minutes to get to the set temperature...30 is better...
__________________
-Serving North Central Texas and Southern Oklahoma since 1978. www.samsservicesenter.com |
The stove/range has been working good for years. So electrical connection isn't a problem. I guess when I said 20-30 minutes to heat up to temperature was a misunderstatement, it sometimes takes 40-60 minutes to heat up, for both the broiler and oven elements. It seemed to be working good one day and then all of a sudden it takes for ever to heat up.
I checked the voltage of the oven element and it running at 119 volts. What could be the problem? |
What could be the problem? __________________________________________________ __________ perhaps the problem is that should be 240 volts??? Need to see where you have lost the voltage to the element, might have a bad breaker or wiring, time to trace back with your volt meter/stick to see where you are loosing the voltage..
__________________
| Display Modes | |
| Oven takes longer to preheat than before | graciesmom | Oven Repair (including Ranges and Cooktops) | 0 | 09-08-2007 09:53 AM |
| Dryer Takes way to long to dry | confused | Dryer Repair | 4 | 08-12-2007 09:38 PM |
| Takes too long to dry:Duet | Scottpiggs | Dryer Repair | 4 | 08-10-2007 01:49 PM |
| oven takes long time to cook | Wmurky | Oven Repair (including Ranges and Cooktops) | 2 | 07-29-2007 01:01 PM |
| Dryer Takes Very Long to Dry Clothes | jdavis | Dryer Repair | 2 | 07-25-2007 05:00 PM |
