Discuss
Burner switch activates oven cycle light.
 in
First time poster, long time lurker. Let me start by saying thank you for your services on these forums, it
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Burner switch activates oven cycle light.
  #1 (permalink)
Old 01-04-2011, 11:05 AM
Junior Member
Floored is on a distinguished road
Default Burner switch activates oven cycle light.
Model Number: JBS07C3WW   Brand: GE   Age: 5 - 10 years
First time poster, long time lurker. Let me start by saying thank you for your services on these forums, it has helped me tremendously over the last couple of years!
Now for the problem. I have a GE range with conventional burners and analog t-stat with no clock/digital display. Pretty plane-jane. The stove works fine, all burners, bake/broil, and pre-heat, however the problem I have is minor and annoying at worst.
When turning on either of the 2 left burners, my 'oven cycle' light lights up, fairly dim though. The far left (back left burner) switch will only activate the light when it's set to 3 or higher. The second from the left (front left burner) activates the oven cycle light at all settings. The oven cycle light also activates with bake/broil as intended and is fairly brighter during this mode.
I have tried replacing 3 switches including one on the right (front right burner) because this one also turned on the light, but once replaced, stopped doing so. However, the other 2, that have been replaced, continue to turn the light on.
There are no wires touching, and I have separated the the wires to make sure it wasn't stray voltage. My problem still remains. Any suggestions?
Ads By Google
Related Models
General Electric JBS07C3WW Electric range
General Electric JBS07H1BB Electric range
General Electric JBS07H2CC Electric range
General Electric JBS07H2WW Electric range
General Electric JBS07PIY1 Electric range
General Electric JBS07PIY2 Electric range
General Electric JBS07PIY3 Electric range
General Electric JBS07T1 Electric range
General Electric JBS07V1 Electric range
General Electric JBS07V2 Electric range
General Electric JBS07V3 Electric range
General Electric JBS07V4 Electric range
General Electric JBS07V5 Electric range
General Electric JBS07V6 Electric range
General Electric JBS08PIC1WW Electric range
General Electric JBS08PIC2WW Electric range
General Electric JBS08PIC3WW Electric range
General Electric JBS12G*R1 Electric range
General Electric JBS12G*R2 Electric range
General Electric JBS12G*R3 Electric range
General Electric JBS12GS1 Electric range
General Electric JBS15F1CT Electric range
General Electric JBS15F1WH Electric range
General Electric JBS15F2CT Electric range
General Electric JBS15F2WH Electric range
General Electric JBS15F3CT Electric range
General Electric JBS15F3WH Electric range
General Electric JBS15H1BB Electric range
General Electric JBS15H1CC Electric range
General Electric JBS15H1WW Electric range
General Electric JBS16*06 Electric range
General Electric JBS16*07 Electric range
General Electric JBS16*F1 Electric range
General Electric JBS16*F2 Electric range
General Electric JBS16*J1 Electric range
General Electric JBS16*J3 Electric range
General Electric JBS16*K1 Electric range
General Electric JBS16*K2 Electric range
General Electric JBS16*N1 Electric range
General Electric JBS16*N3 Electric range
General Electric JBS16*P1 Electric range
General Electric JBS16*R1 Electric range
General Electric JBS16*R2 Electric range
General Electric JBS16*R3 Electric range
General Electric JBS16G*F1 Electric range
General Electric JBS16G*F2 Electric range
General Electric JBS16G*J1 Electric range
General Electric JBS16G*J3 Electric range
General Electric JBS16G*K1 Electric range
General Electric JBS16G*K2 Electric range
General Electric JBS16G*N1 Electric range
General Electric JBS16G*N2 Electric range
General Electric JBS16G*P1 Electric range
General Electric JBS16G*P2 Electric range
General Electric JBS16G*R1 Electric range
General Electric JBS16G*R2 Electric range
General Electric JBS16G*R3 Electric range
General Electric JBS16GS1 Electric range
General Electric JBS16GS2 Electric range
General Electric JBS16GV1 Electric range
General Electric JBS16GV2 Electric range
General Electric JBS16GV3 Electric range
General Electric JBS16S1 Electric range
General Electric JBS16S2 Electric range
General Electric JBS16V1 Electric range
General Electric JBS16V2 Electric range
General Electric JBS17G*R1 Electric range
General Electric JBS17G*R2 Electric range
General Electric JBS17G*R3 Electric range
General Electric JBS17GS1 Electric range
General Electric JBS17GS2 Electric range
General Electric JBS17GV1 Electric range
General Electric JBS17GV2 Electric range
General Electric JBS17GV3 Electric range
General Electric JBS18G*R1 Electric range
General Electric JBS18G*R2 Electric range
General Electric JBS18G*R3 Electric range
General Electric JBS18GS1 Electric range
General Electric JBS18GS2 Electric range
General Electric JBS18GV1 Electric range
General Electric JBS18GV2 Electric range
General Electric JBS18GV3 Electric range
General Electric JBS21G*H1 Electric range
General Electric JBS21G*J1 Electric range
General Electric JBS21G*J3 Electric range
General Electric JBS21G*K1 Electric range
General Electric JBS23BB1 Electric range
General Electric JBS23BC1AD Electric range
General Electric JBS23BC1CT Electric range
General Electric JBS23BC1WH Electric range
General Electric JBS23BC2AD Electric range
General Electric JBS23BC2WH Electric range
General Electric JBS23BD2WH Electric range
General Electric JBS23BD3WH Electric range
General Electric JBS23BY1AD Electric range
General Electric JBS23BY1WH Electric range
General Electric JBS26*07 Electric range
General Electric JBS26*55 Electric range
General Electric JBS26*F1 Electric range
General Electric JBS26*F2 Electric range
General Electric JBS26*F3 Electric range
General Electric JBS26*F4 Electric range
General Electric JBS26*J1 Electric range
General Electric JBS26*J3 Electric range
General Electric JBS26*K1 Electric range
General Electric JBS26*N1 Electric range
General Electric JBS26*N3 Electric range
General Electric JBS26*P1 Electric range
General Electric JBS26*R1 Electric range
General Electric JBS26*R2 Electric range
General Electric JBS26*R3 Electric range
General Electric JBS26C1AD Electric range
General Electric JBS26C1CT Electric range
General Electric JBS26C1WH Electric range
General Electric JBS26C2AD Electric range
General Electric JBS26C2CT Electric range
General Electric JBS26C2WH Electric range
General Electric JBS26C3CT Electric range
General Electric JBS26C3WH Electric range
General Electric JBS26C4WH Electric range
  #2 (permalink)
Old 01-04-2011, 03:15 PM
Junior Member
Default
Figured out what the problem was. Both of the left burners had ground out allowing for voltage to pass through the neutral wire feeding the oven cycle indicator light.
Consider this problem fixed.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven burner wont light or takes a long time to light shadyray Oven Repair (including Ranges and Cooktops) 4 01-30-2011 08:26 PM
Oven burner won't light kencroz Oven Repair (including Ranges and Cooktops) 0 11-21-2009 10:52 AM
oven burner will not light rockerjim Oven Repair (including Ranges and Cooktops) 0 08-09-2009 08:13 AM
Gas Oven Burner Will not light Matthew Wakefield Oven Repair (including Ranges and Cooktops) 2 11-30-2007 05:50 AM
oven burner won't light doc Oven Repair (including Ranges and Cooktops) 1 11-16-2007 02:01 PM
