Discuss
GE Profile gas oven Ignitor Connections question
 in
A year ago thanksgiving, we had the oven ignitor replaced.(501A)(appliance service person) That ignitor had wires that had been very
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Profile gas oven Ignitor Connections question
  #1 (permalink)
Old 01-02-2011, 06:29 PM
Junior Member
meltmtl is on a distinguished road
Default GE Profile gas oven Ignitor Connections question
Brand: GE   Age: 1 - 5 years
A year ago thanksgiving, we had the oven ignitor replaced.(501A)(appliance service person) That ignitor had wires that had been very hot. About half way betgween the ignitor and the connecting terminal the insulation covering the wires was blackened. A new ignitor solved that issue.
Today the oven quit again and when i removed the ignitor, the plastic connection terminal was baked. Looks like the terminal on the wires from the oven controls is useable, but definately overheated. The connector on the ignitor is toasted. Any suggestions to cure that problem?? Seen it before?? And, can the connector on the control side be replaced easily, or does GE have a new pigtail with the connector on it?? Thanks for any info.
Ads By Google
  #2 (permalink)
Old 02-05-2012, 01:23 PM
Junior Member
mattamhop is on a distinguished road
Default
I just saw the same problem on my same oven.
  #3 (permalink)
Old 02-05-2012, 02:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the complete model number of the oven?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #4 (permalink)
Old 02-05-2012, 04:31 PM
Junior Member
Default
Quote:
That would be: PGS968TEM2WW
Have you got a fix? The plug on my ignitor was pretty badly damaged by head. It is black, one of the locking clips on the side was melted/burned off and the other just crumbled when I touched it. The other end (stove end) was mostly black with a bit of white at the far end.
  #5 (permalink)
Old 02-05-2012, 06:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like the plug was exposed to high heat. The best solution is to avoid using this plug and splice in the new igniter, using a high temperature porcelain wire nuts. You can use the oven igniter made by GE which does not have a plug, cost less money, has longer wires and comes with the high temperature wire nuts.
- The oven igniter Part number: AP2634719
Here are the breakdown diagrams and Replacement parts for General Electric PGS968TEM2WW GAS RANGE | AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
electrical connections for GE oven igniter rayak Oven Repair (including Ranges and Cooktops) 0 11-14-2010 03:03 PM
Oven Wire Connections Kream Oven Repair (including Ranges and Cooktops) 2 12-25-2009 05:39 AM
GE Profile pump electrical connections kipoc Dishwasher Repair 4 03-29-2009 06:05 AM
Ignitor test question davedorsett Oven Repair (including Ranges and Cooktops) 3 01-12-2009 10:24 AM
ignitor question Rod Weeks Oven Repair (including Ranges and Cooktops) 0 11-15-2007 06:14 PM
