Discuss
Oven does not light
 in
A round igniter glows to bright orange within seconds of turning on the oven and I smell gas but oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven does not light
  #1 (permalink)
Old 11-28-2008, 12:55 AM
simonyoung simonyoung is offline
Junior Member
simonyoung is on a distinguished road
Question Oven does not light
Model Number: EA91-5CLXM5P   Brand: Magic Chef   Age: More than 10 years
A round igniter glows to bright orange within seconds of turning on the oven and I smell gas but oven will not light. It is a build-in oven made by Gaffers & Sattler (a division of Magic Chef) in early 1980. The model # is EA91-5CLXM5P and serial # is 09357GA. Please advice and thank you.
The orifice hood looks like in the correct position for nature gas. I open up the air shutter and I can light up a small flame inside with a match. However the burner will not light.
Your online parts only shows flat igniter and it says that does not replace round igniter. Where can I found a round one?
Related Models
Whirlpool EAC50
Whirlpool EAC51
Whirlpool EAC511
Whirlpool EAD15JTWR0
Whirlpool EAD191SKWR1
Whirlpool EAD191XMWR1
Whirlpool EAD191ZKWR1
Whirlpool EAD19GKWR0
Whirlpool EAD19GKWR1
Whirlpool EAD19GTWR0
Whirlpool EAD19PMWR0
Whirlpool EAD19PMWR2
Whirlpool EAD19PMWR3
Whirlpool EAD19PMWR4
Whirlpool EAD19PTWR0
Whirlpool EAD19PTWR2
Whirlpool EAD19PTWR3
Whirlpool EAD19PTWR4
Whirlpool EAD19SKWR0
Whirlpool EAD19SKWR1
Whirlpool EAD19SKWR2
Whirlpool EAD19SKWR3
Whirlpool EAD19VKWR0
Whirlpool EAD19VKWR4
Whirlpool EAD19VMWR0
Whirlpool EAD19VMWR2
Whirlpool EAD19XMWR0
Whirlpool EAD19ZKWR0
Whirlpool EAD221NKWR0
Whirlpool EAD221XMWR0
Whirlpool EAD22NKWR0
Whirlpool EAD22PMWR0
Whirlpool EAD22PMWR1
Whirlpool EAD22PMWR2
Whirlpool EAD22XMWR0
Whirlpool EAD251MMWR0
Whirlpool EAD251MMWR1
Whirlpool EAD25MMWR0
Whirlpool EAD25PM0
Whirlpool EAD25PMW1
Whirlpool EAD25PMW2
Whirlpool EAD25PMW4
Whirlpool EAH06CW0
Whirlpool EAH06CW2
Whirlpool EAH06CW3
Whirlpool EAH09CW0
Whirlpool EAH09CW1
Whirlpool EAH09CW2
Whirlpool EAH15CW0
Whirlpool EAH15CW1
Whirlpool EAH17FW0
Whirlpool EAH17FW1
Whirlpool EAH17FW2
Whirlpool EAH22FW0
Whirlpool EAH22FW1
Whirlpool EAH27FW0
Whirlpool EAL12CTWR0
Whirlpool EAL14CTWR0
Whirlpool EAT12DTWR0
Whirlpool EAT12DTWR1
Whirlpool EAT13DTWR0
Whirlpool EAT13DTWR1
Whirlpool EAT13DTWR3
Whirlpool EAT13JTWR0
Whirlpool EAT13JTWR3
Whirlpool EAT14DTWR0
Whirlpool EAT14STWR0
Whirlpool EAT151PKWR0
Whirlpool EAT151PKWR1
Whirlpool EAT15JMW0
Whirlpool EAT15JMW1
Whirlpool EAT15JMW3
Whirlpool EAT15JMW4
Whirlpool EAT15JMWR0
Whirlpool EAT15JMWR1
Whirlpool EAT15JMWR3
Whirlpool EAT15JMWR4
Whirlpool EAT15JTW0
Whirlpool EAT15JTW1
Whirlpool EAT15JTW3
Whirlpool EAT15JTW4
Whirlpool EAT15JTWR0
Whirlpool EAT15JTWR1
Whirlpool EAT15JTWR3
Whirlpool EAT15JTWR4
Whirlpool EAT15PKWR0
Whirlpool EAT15PKWR1
Whirlpool EAT15PKWR3
Whirlpool EAT15PKWR4
Whirlpool EAT171HKWR0
Whirlpool EAT171NKWR0
Whirlpool EAT171NKWR2
Whirlpool EAT171NKWR4
Whirlpool EAT171NKWR5
Whirlpool EAT171PMW0
Whirlpool EAT171PMW2
Whirlpool EAT171PTW0
Whirlpool EAT171PTW2
Whirlpool EAT171PTWR3
Whirlpool EAT171VKWR0
Whirlpool EAT171VKWR2
Whirlpool EAT171VKWR3
Whirlpool EAT172HKWR0
Whirlpool EAT17GKWR0
Whirlpool EAT17JTWR0
Whirlpool EAT17JTWR1
Whirlpool EAT17JTWR3
Whirlpool EAT17JTWR4
Whirlpool EAT17NKWR0
Whirlpool EAT17PMW0
Whirlpool EAT17PMW1
Whirlpool EAT17PMW2
Whirlpool EAT17PTW0
Whirlpool EAT17PTW1
Whirlpool EAT17PTW2
Whirlpool EAT17PTW3
Whirlpool EAT17PTW4
Whirlpool EAT17PTWR0
Whirlpool EAT17PTWR1
Whirlpool EAT17PTWR2
  #2 (permalink)
Old 11-28-2008, 02:42 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
The model number you posted does not come up. Possible due to age. Call APP customer service at 877-477-7278 and ask for Adam. He will take care of it.
__________________
  #3 (permalink)
Old 12-04-2008, 03:17 PM
Junior Member
Default
Dear Gene,
Thanks for your kind reply. Would you please help me for the following question.
I just took some measurements on the igniter (parts# GR-402) and bi-metal safety valve (parts# NC-1425-5A). The electric current is 2.59 amperes into valve and voltage across safety valve is 3.1v. The safety valve voltage spec calls for 3.3/4.0 VAC. My intuition tells me that bi-metal valve is bad. However, the lower voltage reading may be caused by defected igniter with a larger resistor. Larger resistor would lower the electric current and hence give a lower voltage across the 2 terminals of the valve.
Well, now I am confused. Which of the valve or igniter that I should replace? Is there possible that neither is defective and I should check on other component?
  #4 (permalink)
Old 12-04-2008, 10:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like the igniter is too weak. Normally the current drawn by a round igniter should be between 2.5 to 3.0 amps. 2.59 amps is very close to the bottom line, causing the gas valve not to open properly.
- The APP part number for the GR-402 round igniter is AP3537311
__________________
  #5 (permalink)
Old 12-05-2008, 12:22 AM
Junior Member
Default
Thank you very much, Gene. I will replace the igniter and hopefully it will work.
Simon
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
magic chef propane oven won't light (has pilot light) A and J Oven Repair (including Ranges and Cooktops) 3 09-19-2008 01:36 PM
Oven burner wont light or takes a long time to light shadyray Oven Repair (including Ranges and Cooktops) 1 09-16-2008 01:37 PM
oven ignitor not clicking, but pilot will light manually and then the oven will work rosscol Oven Repair (including Ranges and Cooktops) 0 09-10-2008 06:37 PM
oven ignitor not clicking, but pilot will light manually and oven work then rosscol Oven Repair (including Ranges and Cooktops) 1 09-03-2008 05:30 PM
Oven igniter clicks twice but oven does not light smanager Oven Repair (including Ranges and Cooktops) 5 01-10-2008 09:28 PM
