Discuss
lost bake element connector wires behind oven wall in wall oven
 in
i was replacing both burned out bake elements in a double wall oven. one replacement went fine. then in the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » lost bake element connector wires behind oven wall in wall oven
  #1 (permalink)
Old 01-01-2011, 08:04 AM
Junior Member
wdeather98 is on a distinguished road
Unhappy lost bake element connector wires behind oven wall in wall oven
Model Number: rye2688w2   Brand: Whirlpool   Age: More than 10 years
i was replacing both burned out bake elements in a double wall oven. one replacement went fine. then in the top oven when removing the old bake element the wire popped off and went back into the hole behind the oven back wall.......help!
Ads By Google
Related Models
Whirlpool RYE2688W2
Whirlpool RYE2688W4
Whirlpool RYE2688W5
Whirlpool RYE2698P
Whirlpool RYE2698P1
Whirlpool RYE2698P2
Whirlpool RYE2698P4
Whirlpool RYE2698P5
Whirlpool RYE2698P8
Whirlpool RYE3500
Whirlpool RYE35001
Whirlpool RYE35002
Whirlpool RYE3600
Whirlpool RYE36001
Whirlpool RYE36002
Whirlpool RYE3650
Whirlpool RYE36501
Whirlpool RYE36502
Whirlpool RYE36503
Whirlpool RYE36504
Whirlpool RYE3652
Whirlpool RYE36521
Whirlpool RYE3661
Whirlpool RYE36611
Whirlpool RYE36612
Whirlpool RYE36614
Whirlpool RYE3663
Whirlpool RYE36631
Whirlpool RYE36632
Whirlpool RYE3665
Whirlpool RYE36651
Whirlpool RYE36652
Whirlpool RYE36654
Whirlpool RYE36672
Whirlpool RYE36674
Whirlpool RYE3750
Whirlpool RYE37501
Whirlpool RYE3760
Whirlpool RYE37601
Whirlpool RYE37602
Whirlpool RYE37654
Whirlpool RYE3780
Whirlpool RYE37801
Whirlpool RYE37802
Whirlpool RYE37804
Whirlpool RYE3860
Whirlpool RYE38601
Whirlpool RYE38602
Whirlpool RYE3960
Whirlpool RYE39601
Whirlpool RYE39602
Whirlpool RYE39604
Whirlpool RYE3967
Whirlpool RYE3980
Whirlpool RYE39801
Whirlpool RYE39802
Whirlpool RYE39804
Whirlpool RYE4760
Whirlpool RYE47601
Whirlpool RYE47602
Whirlpool RYE47652
Whirlpool RYE47654
Whirlpool RYE4865
Whirlpool RYE48651
Whirlpool RYE48750
Whirlpool RYE48751
Whirlpool RYE48752
Whirlpool RYE48754
Whirlpool RYE7000W
Whirlpool RYE7000W1
Whirlpool RYE7000W2
Whirlpool RYE7000W4
Whirlpool RYE7060W
Whirlpool RYE7060W1
Whirlpool RYE7060W2
Whirlpool RYE7060W4
Whirlpool RYE7100W
Whirlpool RYE7100W1
Whirlpool RYE7100W2
Whirlpool RYE7100W4
Whirlpool RYE7100W5
Whirlpool RYE7160W
Whirlpool RYE7160W1
Whirlpool RYE7160W2
Whirlpool RYE7160W4
Whirlpool RYE7700P8
Whirlpool RYE7700W
Whirlpool RYE7700W1
Whirlpool RYE7700W2
Whirlpool RYE7700W5
Whirlpool RYE7700W9
Whirlpool RYE7760P8
Whirlpool RYE7760W
Whirlpool RYE7760W1
Whirlpool RYE7760W2
Whirlpool RYE7760W5
Whirlpool RYE7760W9
Whirlpool RYE7860P
Whirlpool RYE7860P1
Whirlpool RYE7860P2
Whirlpool RYE7860P4
Whirlpool RYE7860P8
Whirlpool RYE7860W
Whirlpool RYE7860W1
Whirlpool RYE7860W2
Whirlpool RYE7860W3
Whirlpool RYE8400W
Whirlpool RYE8400W1
Whirlpool RYE8400W2
Whirlpool RYE8400W4
Whirlpool RYE8700H
Whirlpool RYE8700W1
Whirlpool RYE8700W2
Whirlpool RYE8700W3
Whirlpool RYE8700W4
Whirlpool RYE9770
Whirlpool RYE97701
Whirlpool RYE97702
Whirlpool RYE97704
Whirlpool RYE9777
  #2 (permalink)
Old 01-01-2011, 08:24 PM
Member
ramblinche81 is on a distinguished road
Default
Quote:
First disconnect all power to your oven.
Second check to make sure you have power off.
Third maybe shut off power to the whole house.
Then, carefully push aside insulation from around the cut out for the bracket which holds the wires and element.
Then, since the wires are going to be heavy gauge, it is unlikely they bent and fell down very low. You can probably use a short coat hanger wire to fish for the wire/bracket and lift it back up to the cut out.
More than likely, it didn't fall, it shifted left or right and is just a little out of sight.
Otherwise, no big deal, you can pull the oven out of the wall. On some models the upper oven can be seperated from lower oven and removed on its own. Look at the installer manual and it will give you some insight.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Wall Oven Won't Bake ToddG Oven Repair (including Ranges and Cooktops) 0 10-24-2010 10:41 AM
Wall oven bake element not working! Broil works, clock works. ajachyra Oven Repair (including Ranges and Cooktops) 1 12-02-2009 06:30 AM
GE Wall mounted oven control sensor wires ovenless Jon Oven Repair (including Ranges and Cooktops) 0 10-21-2009 03:19 PM
Maytag Electric Wall Oven upper bake element won't heat Keithmcelroy Oven Repair (including Ranges and Cooktops) 0 09-06-2009 09:52 AM
How to check the wires on bake and heating element in oven Ladybugg Oven Repair (including Ranges and Cooktops) 0 12-28-2008 05:46 AM
