| » F3 on Frigidaire after replacing oven sensor |
Model Number: REG74BF*0 Brand: Frigidaire Age: More than 10 years
I just replaced the oven sensor on my Frigidaire yesterday and I'm still getting the F3 code after cooking at 400 degrees for 20 minutes.
"F3" error code means "open sensor".
Locate the sensor plug at the control board, unplug it and check the resistance between the sensor terminals. It suppose to be about 1100 Ohms at the room temperature. Make sure there is a good connection at this plug. Pull the oven. Remove the back cover and eliminate the sensor plug, using a high temperature porcelain wire nuts. If it would not solve the problem, then the control board has to be replaced. Unfortunately this part is no longer available. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
Thanks |
It can be a two, three or five wires plug. Look for the wiring diagram inside the control panel or trace the wires from the sensor.
__________________
| Display Modes | |
| GE Oven - F3 after replacing oven temp sensor | robjcici | Oven Repair (including Ranges and Cooktops) | 16 | 01-08-2011 03:38 PM |
| Replacing outer glass on Frigidaire oven door | 4Manny | Oven Repair (including Ranges and Cooktops) | 1 | 08-13-2010 06:09 PM |
| replacing oven sensor | mikeinfl | Oven Repair (including Ranges and Cooktops) | 0 | 02-01-2010 04:35 PM |
| oven sensor question/WB21T10007 GE Oven Sensor | lynnmta | Oven Repair (including Ranges and Cooktops) | 0 | 07-18-2009 07:51 AM |
| Replacing oven sensor | Jemper | Oven Repair (including Ranges and Cooktops) | 6 | 06-16-2008 02:51 PM |
